Question about Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook
My toshiba laptop will only run when I have it plugged in. I have a couple of these computers so I know the battery is charging but just does not switch over to run from battery.
  • Shyny Saxena
    Shyny Saxena May 11, 2010
    As you are very sure that battery is charging then such switching from power supply to battery is avoided by battery module. Actually, this module is between the battery and laptop's power interface. And its not also safe to open you laptop and try to repair it. So i recommend you to go for a technician and ask him to perform this task for you... rate this solution if it is really helpful to you
  • 44 Answers
You said you have 2 laptops. try the battery of that laptop on the known good working unit if it power up without the ac adapter plugged in then its a motherboard problem. basically swap the batteries. then the next option for you is to update your laptop's BIOS, and if that doesn't work, replace the motherboard.
Posted on Apr 24, 2009
Laptop battery plugged in,not charging
Try draining the battery completely and then charge it fully with the laptop switched off.
If you don't know how to drain it out completely, please let me know.
Jul 02, 2017 | Toshiba Satellite X205-S9359 Notebook
Hi, I've recently obtained a Toshiba Satellite
Have you since re-inserted the battery to see if it charges? A battery that is past its ability to hold a charge may show as fully charged, but will discharge usually instantly if put under load and one that has deteriorated to the point of no longer accepting or retaining a charge can cause problems that you have described. The best way is to obtain another battery and test that in the laptop. If that too fails, the issue is likely to lie in the charging circuit. Some laptops, the Packard Bell easynotes were notorious for this.
It is also good practice to remove the battery once charged and running on mains, as this extends the battery life
Dec 24, 2010 | Toshiba Satellite A45-S151 Notebook
Toshiba Satellite 1905-S301 , will it run on a/c power with the battery out?? Not showing that it's charging when plugged in.
Yes it will run without battery in place... it not you may have charger plug or lead problem... let me know...
Oct 12, 2010 | Toshiba Satellite 1905-S301 Notebook
My computer won't turn on or charge.
You need to diagnose the problem.
>First try to take the battery out of the computer and just use the charger to make computer run.
>If it turns on it means that the battery is what's causing the problem.
>But, if computer cannot run using the charger/AC Adapter then it means that we have a problem with the charger.
By doing this diagnostics you know which part to replace.
Sep 30, 2010 | Toshiba Satellite A85-S107 Notebook
My laptop won't turn on even though it's plugged into the recharg
Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone.
Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Laptop not charging
So confusing...Laptop AC Adapter nowadays has AUTOMATIC VOLTAGE, meaning it doesn't matter if it is 110v or 220v. Maybe you've got a FAULTY BATTERY. Remove the battery and plug in your AC Adapter to outlet and to your laptop and try to power-on.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Toshiba m300 charging trouble, stops charging when notebook is started.
sounds like the battery is showing that there is not much reserve..you may need to do a couple of deep discharge cycles..
Oct 13, 2008 | Computers & Internet
Toshiba A100 Power problems
here are few laptop troubleshooting guide to troubeshoot ur laptop. it has one post about power problem of laptop.
I hope this laptop troubleshooting help to solve ur problem. or chekc ur laptop with another working battry or try to start laptop to without battery. and chekc ur power cable for charging is working or not
May 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
