Question about Imation (15706) CD-R Storage Media
CD too full to read
Hi, I had photos on a CD. they didn't fill the CD and now I've added some more to it. The CD is 702MB and now has 11.6MB free space. However it won't let me view the photos and just reads the CD as blank. Anyone got any thoughts?? Thanks
    Scholar:
  • 116 Answers
A cd cannot be to full to read. :)
If you can i would close the session. You may need to use nero or some other program to do that. Then try again. It sounds more like your second burn failed and corrupted the cd.
What software do you have available to you?
Posted on Oct 10, 2007
SOURCE:
Computer read out stuck on full
Assuming this is the readout on the server and not the LCD of teh brewer.
Clean out the servers with detan tablets following manufacturers instructions. Rinse and dry. If display remains unaffected and reads full then the sensor is likely faulty and this means a replacement section.
Jun 04, 2013 | Fetco International LUXUS® 5000 CBS-52H-15...
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
I have a just bought a repaired Olympus FE-4030 from Target for a discount. I have only taken 14 photos but it is showing up as memory full. There are no photos showing up from previous owner. Does this...
You didn't specify the resolution and compression you're using, but the chart on page 49 of the manual shows that you can expect only 6 images in internal memory at full resolution. Off hand, I'd say 14 sounds right if you've set the resolution down a notch.
Jun 18, 2011 | Cameras
Transmission fill, how do you fill
If adding from empty, (just installed new or used unit) put at least four or five quarts in (through dipstick tube). Then, start the engine, leave it in park on a level surface and continue filling 'till it reads full on the dipstick. After it's full put the rear on jackstands and run it in drive and let it shift gears, idle down and shut it off. Don't attempt to put it into park 'till the rear wheels stop turning. Then put it on the ground and re-check level.
If adding to a low unit or after a filter change, just fill on a level surface running till it reads full. In either case, when finished, drive it and when you return re-check level. Always check for leaks.
May 18, 2011 | 1987 Dodge Ram 50
PC would not open up. "Boot from CD" error message pops up.
Probably means that you have a problem with your operating system. This can be for a variety of reasons, which I probably can't figure out from the description. I'd recommend contacting whoever sold you the computer and inform the that you need new CDs for your operating system, (hopefully they will send you them for free, some companies charge a fee). When you put this CD in the tray and turn on your computer, you're going to have to watch for something on your screen that says press "F(some number, usually 10 or 12) to change boot order" After that, look for any option that sounds like a CD drive, and boot from that.
Unfortunately, there is a high likelihood that you'll be required to wipe the contents of your hard disk. That means deleting all of your photos, music etc. This *might not* happen, I've had a similar issue with reinstalling Windows XP and it didn't delete anything on my computer.
May 03, 2011 | Microsoft Windows XP Home Edition Service...
My DVD+/-R drive wont write
If the reading is also bad, then you have a hardware problem. Try to get a lens-cleaning disk, or clean the lens yourself VERY softly. If that won't work, you'll have to replace it.
Be sure to have the "write" or closely to that option selected in your burning software. You may only simulate the write...
Nov 29, 2009 | Toshiba Satellite L305-S5911 Notebook PC
My DVD Drive Showing Every cd/dvd as empty as it is not empty...
wel the only option 4 u is to install linux or
format ur by C drive usin linux NTFS format!!
Mar 31, 2009 | Pioneer DVR-107D DVD±RW Burner
Computer says cd blank but it has data
try cleaning your cd or dvd drive and then clean your CD with brasso or shampoo without scraching it with soft hand.
wipe the cd in outwards direction from the center
gud luck
bye
Nov 20, 2007 | Compaq Presario Notebook
Imation (15706) CD-R Storage Media Logo
74 people viewed this question
Top Imation Electronics - Others Experts
 Mike M
Mike M
Lawrence Oravetz
Paul Ronco
Level 1 Expert
Are you an Imation Electronics - Other Expert? Answer questions, earn points and help others
