Question about Toro TimeCutter SS5000 - 22HP 50 Zero Turn Mower
Toro Timecutter ss5000 has a whine at full throttle only when blades engaged. Lower throttle, no whine.
5 Suggested Answers
  • 6468 Answers
SOURCE: toro lx 500 deck belt pops off
check for play in the bearings blade bearings and the idler pulleys
Posted on Apr 15, 2012
  • 6468 Answers
SOURCE: toro riding lawn mower pto switch not engaging to turn blades
see if you have power and ground to the connector that goes to the clutch it could be a bad safety switch
Posted on May 22, 2012
philwalker78
  • 608 Answers
SOURCE: TORO MOWER MODEL 22168 VIBRATION
Hi, most likely cause is a bearing failed in the pto. Regards Phil.
Posted on Oct 10, 2012
BAMOUT
  • 2478 Answers
SOURCE: How do I replace the belt on a toro ss5000 #74630 timecutter
Go to you tube On the line replace belt toro etc.
Posted on Jun 21, 2014
How to check the charging system on a toro timecutter ss5000
The battery should show about 1.4- 2 volts higher than the voltage rating of the battery when the engine is running at high idle.
Jun 18, 2017 | Toro Garden
Timecutter ss5000 loses power
check for rusted or failing bearings on the cutter shafts
Oct 02, 2016 | Toro TimeCutter SS5000 zero turn mower
Why does motor try to stall after cutting for 30 or more minutes? Acts like it is running out of gas but has full tank.
check your gas cap
then check the fuel lines, if they are soft or spongy, replace
then check for spark
in this order
Aug 20, 2014 | Toro Zero Turn TimeCutter SS Series SS5000...
My blades wont come on when i pull up on the switch.never had this problem before.
The switch operates a solenoid. Check the condition of the wiring before you replace anything. I don't know if its similar to a JD but that operates an electric clutch on the drive. Check it out.
Aug 15, 2014 | Toro TimeCutter SS5000 50" 22HP Lawn Mower...
Jun 21, 2014 | Toro Garden
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
Toro TimeCutter SS5000 - 22HP 50 Zero Turn Mower Logo
20 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
