Question about Toro TimeCutter SS5000 zero turn mower
Whine at full throttle when blades engaged - Toro TimeCutter SS5000 zero turn mower
Cranks, runs good at full throttle, then rpm falls when deck engaged ?
check for blade carrier bearings seizing up from rust making if difficult to turn the blades
May 06, 2016 | Garden
What else could be wrong with my 12.5 hp kohler engine?
Is the engine sluggish and slow to pick up when throttled up?
Jul 17, 2014 | Cub Cadet Garden
Idle rolling
are you talkin aboutit surgin up and downat high idel thats normal when you engage the blades it levels out under load
Oct 26, 2012 | Craftsman Garden
Craftsman lt 2000 42
Hi, first check the spring that pulls on the idler pulley for lost tension then run the blades for a 10 to 15 minutes at half to full throttle. This is necessary to bed the new belt into the old pulleys. Regards Phil.
Sep 05, 2012 | Garden
Tractor starts fine on full choke, but as soon as you put it on throttle it cuts out. it also cant sustain it if you engage gear or turn on the blades to start cutting
You may have something stuck in the mower deck. If you nuse a mirror you can look under the deck and see if anything is jammed there. If the blades are jammed it will stall the motor.
May 04, 2010 | Garden
When engaging mower blades speed drops or stops
Check throttle cable at carb and make sure you have full travel. Sounds like rpm is little to low. Throttle cables are usually held in place with 1 screw and a washer. Put cable at full throttle loosen screwand pull back until throttle at carb in at full then tighten screw.
Mar 07, 2010 | Garden
Blades wont engage on a john deer riding mower
May be a safety switch not letting the PTO engage the clutch? Also check your voltage at the battery...too low a voltage won't let the clutch engage either. Should be between 13.3-14v at full throttle.
Sep 09, 2009 | Garden
Toro TimeCutter SS5000 zero turn mower Logo
26 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
