Question about Dishwashers
Maytag dishwasher problems pdb3600awx
Dishwasher wont drain.found plastic in bottom.need to know how to take off bottom spinning part.
SOURCE: Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Posted on Feb 26, 2008
ginko
  • 19396 Answers
SOURCE: Maytag - MDB4800AWB - water will not drain
If water is not draining, check first that the drain hose is not obstructed. Try also advancing manually the timer/[programmer.
If water is still not draining, it may be a faulty drain pump, aproblem with belt/motor , or a defective timer/control panel.
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon."
from The water doesn't drain from the machine
Posted on Sep 27, 2008
eastelect
  • 9 Answers
SOURCE: Maytag Dishwasher won't drain
on all dishwasher think of them as a simple gutter system. the water only has one drain. At the bottom, if the pump can't pump out the water, its simply a bad pump or a clogged drain hose. Food particle can clog the "drain screen", use a good quality shop vac, clean 'drain screen', remove drain hose and clean thoroughly. If the hose goes into your drain pipe, remove that and clean that really good with snake it its metal or a strong 1/2 zip tie if its plastic.
Posted on Nov 30, 2008
danromarris
  • 101 Answers
SOURCE: Lower spray arm won't spin
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Posted on Jan 22, 2009
  • 220 Answers
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Posted on Sep 26, 2009
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
I have a maytag dishwasher #PDB3600AWX and it just isn't cleaning the dishes. Does it have a water filter that can be cleaned?
It might be hard water deposits on your dishes. Go here to find out if you have hard water. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
Wont drain
check to make sure it is level. top to bottom, side to side.also make sure you check the drain hose for clogs.
Aug 04, 2011 | Maytag Dishwashers
Clogged dishwasher?
disconnect the drain hose from the disposal or under the sink use a 5 or 6 foot long piece of plastic ice maker hose run it down the dishwasher drain hose till it want go any more also put one cup of bleach in the bottom of the dishwasher and let it set for at least 1 hour then turn the dishwasher on to drain and see if that cleared your clog
Mar 30, 2010 | Maytag 24 in. MDB5600A Jetclean II...
We have a Maytag dishwasher. The first thing I noticed was the soap oozing down the door, but it also appears that the spray arms aren't moving. The water is sitting in the bottom of the dishwasher.
Depending on your model number, Maytag dishwashers on one model have combined drain pump & spray arm pumb. On other Maytag units these pumps are stand alone pumps. Check to make sure that:
1: drain hose to drain pipe(disposal) is open and flows well, do this by disconnecting the hose from disposal end and lay flat (in a pan) on floor and see if water comes out, if it does hose is clear of gunk.
2: Check garbage disposal inlet tube where drain hose connects, if your recently installed disposal then you may have forgot to remove plastic plug,
3: Turn spray arms by hand and make sure they spin freely,
4: make sure that when you close the door it latches and you can hear the pump running.
If all the above are ok, then you have a drain/motor gone down and will need to replace it. Give us a model number and we can advise better where else to look.
Nov 12, 2009 | Dishwashers
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher overflows
Sounds like you've got a problem with the water intake valve(s). If it takes on water without water running in the sink, that is where I would look. If it happens when you use the sink, then I would also check your drain hose placement
Jun 22, 2009 | Dishwashers
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag portable dishwasher is not draining
try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
Dec 05, 2008 | Maytag MDB9600A Jetclean II Built-in...
Nov 30, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
