Question about GE 24" Built-In Single Gas Wall Oven
General electric wall oven parts number wb19x5280 ge clock/timer
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
aborcass
  • 2651 Answers
SOURCE: F3 Error Code - GE Electric Oven JTP18
all ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 23, 2008
  • 112 Answers
SOURCE: GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Posted on Oct 25, 2008
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
  • 19 Answers
SOURCE: F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
Posted on May 09, 2009
I have a GE electric oven mode JSP48G*J2. It has a mechanical clock/timer that has gone bad. The replacement part is WB19X10007, but I'd like to see the instructions for installing this before I go spend...
Normally the mechanical timers have only 2 terminals. Active supply in and oven load out. It doesn't matter which wire you put where. If you don't use the timer just join the active supply and the load together and the oven will work.
Feb 15, 2011 | GE Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
GE Profile Wall Oven Circuit Board
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Apr 25, 2010 | GE Profile JTP18 Electric Single Oven
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
Dead trivection oven by ge JT9300h1ss
This model has issues with the power input controller board, usually caused by surge following a power failure... board is $285 from GE plus $90 or so to install after paying a $100 service call. Replacment part is special ordered and generally takes a week or so.... have 2 of these ovens... ask me how I know.... LOL
May 30, 2009 | GE Profile JTP18 Electric Single Oven
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
I need a replacemnt Time clock unit for GE Doubleoven JKP39G0K2BG
Part number is good...WB19X5280 and while it is no longer available in new, there are companies out there on the net that can actually rebuild your electronic control. Cost would be somewhere around one hundred dollars. Search the net for electronic clocks rebuilt. You will save a range and bake many more cakes once repair is made. Good Luck. If I can help further...
Waiting to hear from you,
Eric Campion
Feb 12, 2009 | GE Ovens
GE 24" Built-In Single Gas Wall Oven Logo
75 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
