Question about Makita BDF452HW Factory Reconditioned 18V Cordless Lxt Lithium Ion 1/2" Driver Drill Kit
Bdf343 chuck repair - Makita BDF452HW Factory Reconditioned 18V Cordless Lxt Lithium Ion 1/2" Driver Drill Kit
Dewalt dcd950 chuck
Its is about a 2 years modified the XRP chucks In Netherlands the model 950 is not QS made for europe but all the XRP machines have had a special solide looking Chuck For the original Chuck there was a special tool to remove the chuck the gearbox must be open to and a special N119912 a complete unit of repair tools to remove the chuck and replace , BUT the new modificated repair is by get a normal standard keyless chuck , asked them for about the modification because of the older repair tools and chuck http://www.2helpu.com/world/map.aspx it's about much more cheaper to choose for modification the N119912 is possible renumbered thats possible the right same tool because of the model DCD 950 is not selled in Netherlands . the DCD945 instead of but it means the same kind of modification .
May 29, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
The chuck wont tighten
The outer sheath of the chuck turns a thread on the back of the jaws in the chuck and it it is not tightening correctly then the jaw threads have been broken/cracked or the jaws have been stressed out of alignment and are not longer closing in a parallel manner. Best replace the chuck as they are generally not repairable.
Nov 08, 2012 | Black & Decker Compact Power Screwdriver
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Can the chuck be repaired? The very top part (plastic) has fallen out, everything else is intact. Thjis is the ring that you hold while adjusting the chuck. Is it worth getting repaired?
Yes you can get a replacement chuck and install it your self. with the chuck open, ( you can still make it open but its not easy inthe bottom of the hole theres a screw that holds it from turning , most of them ar ebackwards thread, ( turn it ti the right to loosen ) with the screw removed and the drill in low gear ( the slower of the two speeds chuck up the short end of a big allen wrenck ( kex key) The chuck has regular threads and you smack the key with a hammer to unwind it. once turning it'll come right off. If you can't get it off it's not worrth fixing as if you need to pay a shop to put it on by the time parts and labor go by a new one can be bought. You might not be able to get the Ryobi chuck but don't worry all the chucks with the same thread sise will fit and work even ones that use keys. they come with both metric and inch threads though so be sure you take the old parts with you to the stroe to match them up. Msot places that rent out tools have a fix it and parts shop too. Look them up under tool repair and tool rental.
Dec 02, 2010 | Ryobi 3-piece 18V Drill / Circular Saw /...
My chuck releases when i use it in reverse.
does the chuck unscrew?? If so what you need to do is tighten the chuck again and look for the chuck retaining screw that locks it into place, you should be able to buy one at any local tool repair center. they are left hand thread. if the jaws are releasing then the chuck might have to be replaced. Let me know if I misunderstood the problem and I will try again.
Jan 02, 2010 | Dewalt 18 Volt Compact Drill Kit
Chuck on bosh electric drill not working it doe not close all the way.
There are no ways to repair a chuck short of spraying lubricant in to it and this rearly fixes the problem you are discribing. You will probably have to replace the chuck. Any Bosch service center will have the chuck you require.
Dec 27, 2009 | Bosch Drills
How can I disassemble a Dewalt keyless cordless drill chuck? I mean take it apart, not just remove it.
depending on the chuck it would take special fixtures to press apart, and unless you are very good with tools you would damage it beyond repair. I have never taken a keyless apart and tried to repair and put together, I have on the other hand done the same with the keyed chucks.
Dec 13, 2009 | Dewalt Drills
Hi my drill chuck is stuck and will not retract, I think the bearings hve gone. How much will a chuck be to be replaced and repaired?
tricky question the size and the cost is important so .repair drill cost versus new drill?
new drill for me sir.
repair chuck may be good but other parts should be repaired once you are inside the drill which is going to cost more.
Aug 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Makita BDF452HW Factory Reconditioned 18V Cordless Lxt Lithium Ion 1/2" Driver Drill Kit Logo
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
