General electric wall oven parts number wb19x5280 ge clock/timer
fridgetech
  • 473 Answers
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Posted on Oct 05, 2007
  • 11 Answers
SOURCE: need part number for a kenmore range clock/timer replacement
part #496225
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: LED Display fading
As noted in solutions to other Jenn Air ovens, this is often solved by replacing the capacitor labeled C3 on the circuit board that contains the display. Oven heat apparently causes it to fail over time. This is a solder connection to the circuit board. Not hard if you have any experience with this kind of soldering it is straightforward.
Seven phillips sheet metal screws to remove panel assembly, plus two electrical connectors. One ribbon connector from touch panel to board, then four 1/4 hex sheetmetal screws to remove circuit board from touch panel and metal frame. Then soldering iron.
It did work on a 40300 dual unit, which is same as this model except for cosmetics.
Capacitor is 35 volt 68 microfarad. Radio shack has 100 microfarad, which one report says works. Radio shack doesn't have a 68, but they do have 22 and 47 which mounted in parallel give 69, which is within tolerance. That's what I used. The capacitors cost $1.29, less than 1% of the cost of a new circuit board.
Posted on Jan 01, 2009
  • 22 Answers
SOURCE: oven won't work - its a timer problem how do I reset the timer?
I believe the control's child lock function is enabled. To disable it, press and hold the cancel key (will have small padlock icon under the word "cancel"). That should clear the condition.
Posted on Apr 25, 2009
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Set the hour on clock on GE electric stove
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
My Ge Mechanical Time Switch (Model number 15087) is losing time. Is there any way to adjust the timer so that it keeps correct time?
There is no adjustment if timer clock is running slow.
Timer clock motors run slow when the motor starts to fail.
There are no replacement clock modules this timer.
Buy a new timer at Home Depot, and swap out insides of timer using 1/4" hex nut driver, and then return defect timer in new box.
http://waterheatertimer.org/GE-timers-and-manuals.html#15207
Aug 05, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
I need a replacemnt Time clock unit for GE Doubleoven JKP39G0K2BG
Part number is good...WB19X5280 and while it is no longer available in new, there are companies out there on the net that can actually rebuild your electronic control. Cost would be somewhere around one hundred dollars. Search the net for electronic clocks rebuilt. You will save a range and bake many more cakes once repair is made. Good Luck. If I can help further...
Waiting to hear from you,
Eric Campion
Feb 12, 2009 | GE Ovens
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
