Motor board LED fllashing 6 times. any way to reset the code for sure ?
GE WHDRR418G1WW motor circuit board LED flashing 6 times. according to GE publication. This condition is lock rotor and motor needs to be replaced at $200 a pop. I open the front panel of the washing machine and tub, motor shaft belt and pully all move freely. is replacing motor the only thing left to do ?
  • jmchen8 Apr 24, 2009
    I bought a motor and hope for the best. It was a bear to finally find the flashing LED between the tight gaps. I worked with various motors, motor controls, variable speed drives of all sort. All motor and control should have protection against 'lock rotor' with an overload trip against damage plus reaet. GE has a poorly designed motor and speed drive with a costly fix. People give this model a thumb up on the web. I suppose the first trouble will change their mind. My unit only lasted a little over an yera. no warrenty :( thanks for the confirmation.
  • Anonymous Mar 24, 2014
    I have a haus washing machine HW50-1010W and need to reset circuit board panel how?
  • 686 Answers
IN YOUR CASE YES BECAUSE TECHNOLOGY MAKES IT THIS WAY ANYMORE. YOUR MOTOR MAY BE A MOTOR TO YOU AND MOST PEOPLE BUT IT IS ACTUALLY AN ELECTRONIC COMPONENT AND IS ELECTRONICALLY CONTROLED. SORRY TO BE THE BEARER OF BAD NEWS. GOOD LUCK
Posted on Apr 24, 2009
Will not spin or agitate
Remove the front panel. Observe the motor flashes.
The motor blinks on and off all the time.
It blinks faster when running.
If a failure occurs you will get the following flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes bad motor
6 flashes locked motor check for objects between tub
7 flashes bad lid switch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes. If no light is visible you have a blown fuse built into the neutral side of the harness on the white/red wire.
themobilian_2813.jpgthemobilian_31.pngIf you see a small bubble in this black heat seal and the motor light is not on then the fuse within is blown replacement part is WH49X10041
What else do I have? Oh yeah how about the SERVICE MANUAL
Aug 12, 2011 | GE Profile WPRE6100G Top Load Washer
Washer will not spin or ajatate. I need to remove the front panel to see what up?
Use downwards force to relieve tension on the spring clips holding that front panel on.themobilian_1904.jpg
Video how to:
Once yall have the front panel removed yall will notice the motor has a green blinking light on it.
The motor blinks on and off all the time It blinks faster when running. That is normalment mon ami.
If it ain't acting right it will display flashes:
1 flash bad motor
5 flashes little green men (bad motor)
7 flashes bad lidswitch.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_26.pngthemobilian_27.png
Service manual and more HERE
Mar 16, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
Hi, I overloaded my washer with towels. It hasn't fully drained (can hear water beneath the tub when you move it). I tried unplugging it for a minute, but the same problem presents itself. When start is...
The motor has a power inverter on top of it. Try and reset the motor by doing this:
Turn the washer off. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. It may take a few times. The motor has a green light on it that blinks. If it ain't acting right it will display flashes:
1 flash bad motor
5 flashes little green men bad motor
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_4.png If you see a liitle bubble in there then you know that dude is toast.
That fuse is: $7.50
Nov 29, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
MODEL #WHDRR418G1WW GE WASHER,THE LIGHT (RED0 ON
unplug unit for 1 minute plug back in and open and close lid 6 times within 12 seconds this will reset the motor.
Feb 26, 2010 | GE Washing Machines
MODEL #WHDRR418G1WW THE RUN MOTOR HAS A RED LIGHT FLASHING 4 TIMES WHATS THIS MEAN
It means the mode shifter is open which means you need a mode shifter and a motor.
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
Washer drains but won't spin.
The next time this condition occuers, take the front panel off the machine and look under the top cover of the motor at the right front side. There is a LED light on the motor inverter board there. If it is flashing twice, then a pause, then repeating this again and again you most likely have a loose hub nut on your wash basket. (the motor reads this as belt slippage)
1. Order and install a new hub washer (WH2X1199) and a new split ring (WH2X1195) along with a new hub nut (WH2X1193). If the hub part of the basket is worn, replace that as well (plastic tub models = WH45X10027, SS tub = hub / basket WH45X10060.
2. Tighten hub nut, torque to 110 ft-lbs.
3. Clear flash code error. (your method to clear code is a bit more extreme than required, but will work)
Mar 30, 2009 | GE WBSR3140DW Top Load Washer
When I push open or close the unit starts but stops the yellow light on rear of unit blinks 4 times then a short pause and blinks 4 times again and continues to do this
# of flashes
6
Rapid Flashing
Problem
The Protector System wire open or totally misaligned
The Protector System wire shorted or black/white wire reversal
Door Control or Multi-Function control Panel wire shorted
IR sensor slightly misaligned (dim or flashing sensor LED)
Motor overheated/Possible RPM sensor failure -- unplug to reset
Motor circuit failure -- replace RX/LX board
Liftmaster transmitter with the correct format code being received
(opener not necessarily programmed to respond)
Mar 28, 2009 | liftmaster Chamberlain Garage Door Opener...
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
I just had a new GE washer delivered to my home today, June 24, 2008. All it will do is fill with water and than drain. The agitator cycle does not work and the spin cycle does not work. Model...
We had the same problem with our new GE washer.......the repairman just left. It's the circuit board on the motor that failed, causing the motor to stop working. GE will replace it under warranty.
Jun 24, 2008 | GE Washing Machines
Washing Machines Logo
439 people viewed this question
Top Washing Machines Experts
