Question about RCA DRC8335
How do I get to at least watch a DVD or VCR
My display screening says Hello. I press on/standyby button and time displays. But when I press any button Hello displays again. Shyrl
    Novelist:
  • 159 Answers
If after the hello display you open the tray and inserted already the dvd push play and the thing is always with the hello and after reasonable time (one minute) and nothing change the display stil with the hello thing:
use another dvd and the same answer.
your dvd is not read in the memory because the set is not able to do it and the memory is waiting for that data. So your Dvd memory is waiting for the mechanism to send that data and say: hello.
So time to visit a repair place. to amke sure about any estimate.
Posted on Apr 24, 2009
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Set clock on sansui vhs dvd player
You must first be sure your remote is set to VCR by pressing the VCR/DVD button.
Then press SETUP/VCR MENU button.
Use your arrow buttons to select SYSTEM SETUP.
On the next screen select CLOCK SET,
Press enter until you get to the time selection.
Use your right arrow to increase or left arrow to decrease the hour or minutes, Then press ENTER.
Press VCR/DVD if you wish to return the DVD display.
Aug 02, 2009 | Televison & Video
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
I would like an unlock code for two vcr/dvd combos. Can you help?
If you need a region free code, here it is:
Make sure you have no disc or tape in
Turn it on.
When the display shows "no disc"…...
1. Press the DVD button on the REMOTE CONTROL so the Samsung DigitALL logo appears on the screen
2. Press the SUBTITLE button on the REMOTE CONTROL
3. Using the REMOTE CONTROL enter the code: 7, 6, 8, 8, 4
4. The current region should be displayed on the screen. (eg "04") If this doesn't happen then turn off
and then on and try again
5. Press the 9 button on REMOTE CONTROL for Region free or new region number
6. Press the Open button on PLAYER
7. Press the Close Tray button on PLAYER.
8. Power the unit off, then power the unit on again
Nov 25, 2008 | Samsung DVD-V4800 DVD Player / VCR Combo
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Display problem
hit the display button
Aug 11, 2008 | GoVideo Go Video DVD/VCR Combo
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
How to set time and date
Turn on. Goto channel 3 or 4. Press DVD/VCR button until display says VCR. Press TV/VCR button until the display says VCR. Press SETUP button. Select SYSTEM SETUP. Select CLOCK SET. Edit time and date. Press SETUP button.
Jan 07, 2008 | Toshiba SD-V394 DVD Player/VCR
RCA DRC8335 Logo
459 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
