Question about Gateway FPD1760 17" LCD Monitor
Monitor problems when I boot my computer up the monitor comes on then the light goes from green to yellow and the screen goes black, it will flash my wallpaper then it goes black???
    Scholar:
  • 113 Answers
Ok ,you may have two monitor drivers installed, or if it is wireless the driver may be faulty etc... a problem like this occur when you have two places on a monitor can be attached to your motherboard, direct or PCI, hat means look at the back of your comp. if there is a similar port that the one your using then when the monitor goes blank and just sits their, switch it over, and you should get an image. if its a driver problem, then safe mode will only work, and reinstall your PCI TO PCI or: your PCI BRIDGE drivers in the computer managment console. good luck. if all fails try using an older monitor or just a spare. cheers.
Posted on Sep 25, 2007
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Acer 2416W monitor comes on for 1 second then goes black
try a different monitor
could be video card problem
best if can try a known good one
does power light stay green and hd light flash like activity continues, can you boot in safe mode, if so might be video driver , also looked for popped capacitors on mb , if computer actually goes off try a know good power supply
Sep 02, 2010 | Computers & Internet
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Rebooting .. no effect on the monitor black blinking yellow light
Hi.
This is a hardware problem. If the machine seems to startup normally (apart from the monitor), then it is commonly caused by the video card coming loose. Turn it on, wait about 2 minutes until the drive activity dies down, then press the power button on the computer once. If the machine shuts down and turns off, then it had booted into windows normally and your data should all still be there. If you have a video card in the machine, unplug it, then re-seat it firmly and try again. If the machine is not booting (it doesn't shut down and turn off with a press of power), then unplug the RAM and the video card and press them back in firmly.
Mark
Mar 14, 2009 | Gateway Computers & Internet
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Gateway FPD1760 17" LCD Monitor Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
