Question about Kenwood Hb724 Triblade Hand Blender
The power button does not turn the blender on
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Ninja Blender 1100 starts then stops almost immediately, is there a way to fix this?
It Could Be a Number of Things..
It's most likely that the electrical Wire Could Have a Shortage, If it cuts off again Try gently Wiggling the Electrical Wire in a Number of Directions If it cuts on and off while your fidgeting with it, you've found your Problem! A quick fix would be to Adjust the wire In the position it would cut on the strongest, wrap the cord with Tape to Keep the wire in that Position, this will Prevent it from shorting again.
Either that or you simply put too much product in the Blender with an inadequate amount of liquid.
Jan 04, 2014 | Blenders
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Mar 21, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blender has power but won"t turn on
Hello and Welcome to FixYa!
Well the mal-function can be due to numerous reasons. You need to choke out each possibility one by one.
Loose Connections ( Check for all the connections to the circuitry and motor). Bad Starter Button ( Check for the button switching using a Multi meter). Bad Motor Winding (Motor bushes or winding can be the bottle neck).
Check for the quoted possibilities and you'll soon find one good reason for the mal-function.. Feel free to ask anything regarding the trouble.
Concerned.
Feb 25, 2011 | Waring 7011S / 7011G Commercial Work Top...
Wont turn on. its plugged in and the switch on the plug socket is turned on
have you fix the container? most blender today has a switch to verify if the blender container is fixed to the motor.
May 31, 2009 | Blenders
Will not work
First ensure that the blender jar is placed on the right orientation, othherwise the blender wont start.
Remove the Jar and place it on the other way if you are not sure.
If you still get the click, try leaving the blender power cord unplugged for a while. The click means that the blender has power, but the motor is not starting.
If it still does not work , and the jar is in the correct way and you did the above, then the blender is faulty, probably a faulty motor, or a broken wiring.
Dec 19, 2008 | Krups 574 Power Xtreme VI Premium Work Top...
Kitchen Aid blender
to see if its the Triac or just the off button perform this: connect the blender,while pressing the off button press the on button; if the blender stays on and you dont hear the relay function (Light ticky sound) maybe the off button get a broken solder point. But if the relay is functioning and there is no way to change the speed the problen is the TRIAC. This is a small piece on PCB with a heat sink
Aug 30, 2008 | KitchenAid KSB3 Classic Work Top Blender
Buttons click but it won't run.
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask, strawsj1234@hotmail.com
Mar 17, 2008 | Black & Decker BL5000 ProBlend Work Top...
Blender stops working
I also have the same problem...it is brand new...worked 3-4 times and stopped. Spent $65 for a nice blender. I will also NEVER buy black and decker again.
Dallas, TX
Oct 12, 2007 | Black & Decker BL1900R Blender
Kenwood Hb724 Triblade Hand Blender Logo
103 people viewed this question
Top Kenwood Blenders Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
