Question about Kenwood Hb724 Triblade Hand Blender
It does not turn on - Kenwood Hb724 Triblade Hand Blender
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
How can I remove the serrated drive coupling from a Krups F577 blender so I can replace it?
Normally they are threaded on, to remove them they need to be shocked to turn in the same direction as they turn when operating. A solid screwdriver and large hammer to whack it to turn in the normal direction it rotates when being used.
Aug 08, 2013 | Blenders
Magic bullet
Blenders usually have some sort of interlock that prevents power from being turned on if the container is not locked in place. This could be the reason for the problem
Apr 25, 2013 | Emson Magic Bullet Express Blender
Blades won't turn when cup is on
check to see if shaft is turning when cup is off if it is somthung is binding it
Sep 24, 2012 | Oster 6804 16 Speed Blender
Ksb50b3 doesn't turn on hums
Does the blade turn by hand? Does the motor turn by hand? The answers to both those questions may point you in the right direction. If both turn freely I would suspect you need a new motor.
Jun 07, 2012 | KitchenAid KSB560 5 Speed Blender
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
My blender won't blend. Everything turns but the blades.
I have no idea what might be turning, but likely you do not have the blades seated if the shafts don't turn... IF the shafts turn, the welds or swaging of the baldes to the shaft have probably come loose due to overloading.
Apr 07, 2010 | Bosch Blenders
Blades need to be greased, but I don't know what to use or how to do it. Motor seems to be working too hard, and blades do not turn. Devise turns when blender container is not on it.
To take the blades off, grab the blades with a rag so you don't cut yourself, then grab the other end with a rag and turn CLOCKWISE - it's reverse threaded, so lefty loosey doesn't work here, it's lefty tighty, so turn to the right. Figured it out after an hour of mental anguish
Oct 11, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Kenwood Hb724 Triblade Hand Blender Logo
51 people viewed this question
Top Kenwood Blenders Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
