Question about Homelite Garden
Why does the string keep coming out or my homelite weedrater..ut32600..
2 Suggested Answers
  • 279 Answers
SOURCE: Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Posted on Jul 26, 2010
My 26cc homelite straight shaft weedeater keeps
If the guard isn't in place and cutting the string to length as it's running, it will keep feeding line out.
Sep 23, 2014 | Garden
Why won't my homelite 79cc edger won't stay running longer than 3-4 minutes?
Try taking your exhaust apart and see if it's clogged. There's a spark arrester that keeps sparks form coming out the exhaust. Basically a screen that can get clogged with oil and carbon. The link is a good site for troubleshooting. String Trimmer Repair Help
Jul 17, 2014 | Homelite Garden
Homelite y 2500 yardmachine trimmer
http://www.odref.com/homelite/string-trimmers/ut-20612r.PDF
May 22, 2014 | Homelite Garden
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
How do I feed string into my Homelite Mighty Lite 26ss grass trimmer? I don't have a manual and I can't figure it out. Thank you!
cut a 6 ft piece and wind it (starting with the middle of the trim line) around the head with each head going opposite directions. When you get it wound up, you will have two pieces sticking out in opposite directions and they can be clipped into the small plastic slots on the edge of the string canister. THen press the ball on, and attach to the trimmer.. Just keep the string the grooves and you will be fine...
OHYEAH!!! dont worry if it keeps coming unwound or pops off the trimmer at first, it will happen until you develop the technique needed for a quick replacement
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Jun 03, 2010 | Homelite Mighty Lite Lawn Trimmer
Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Garden Logo
16 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
