Question about Amana PTC153D35AR Central Air Conditioner
Contact not engaging all the time
I have a heat pump that the outside unit sometimes doesn't engage the compressor. I have taken the panel off and it kicks on, on one occasion others I have had to tap on the contactor. Now I have to engage the contactor manually. By doing this it jumps 4 or 5 times and engages fine for a day or 2 then stops engaging again. Want to get this fixed before I damage the unit.
  • 22 Answers
It can be your power going to the contactor, most likely 24 volts or the contactor itself. If you are not trained and do not have any electrical experience at all seek professional help.
Posted on Dec 23, 2013
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
Replace old contractor by new one
Posted on Oct 15, 2013
SOURCE: Amana ac/heating unit model PGD60C1152E
It sounds like your blower is coming on before your heat. With gas if your unit is new enough, typically you have an ignition mode to start your heat process, flame recognition, and then full burners, heating up your heat exchanger, and then bringing on your blower. Your blower maybe controlled by a circuit board, just depends upon age of your system.
Posted on Nov 20, 2007
  • 25 Answers
SOURCE: 1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Posted on Nov 22, 2008
  • 85 Answers
SOURCE: My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Posted on Dec 03, 2008
  • 534 Answers
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Posted on Aug 04, 2009
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
johnsonr1
  • 91 Answers
SOURCE: contactor will not engage i have 240 at contactor
Have you checked the contactor coil voltage? It should be 24V. It will be the smaller wires either on the top/bottom of the contactor or on the sides of it. Turn the 240 V off prior to checking the low voltage to ensure you do not get electrocuted. If you have voltage at this point, then the contactor coil is defective and you will have to replace the contactor. About 25$ US at most electrical supply houses.
Posted on Sep 12, 2009
Trane XR15 not starting. Has power. There is a contact switch that when engaged the system fires up but coil gets cold but not circulating through the air handler. Could it be capacitor related?
So the contactor pulls in outside, the fan and compressor both start?? Then you say the coil gets cold... what coil is getting cold and is this a heat pump and are you trying to cool the house???
Jun 08, 2017 | Heating & Cooling
I have an amana heat pump a/c PTAC unit 14700 btu and it seems the compressor is not engaging or blowing cold air
could be a bad run capacitor or the unit needs to be cleaned take it outside and wash the condenser coil the outside coil and the evap coil on the inside be careful not to get the electric circuits inside the unit wet. I would wash the coils first and then see if it cools. Hope this helps
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
Air Conditioner Compressor Clutch Problem
If you did not use a vacuum pump from a dry system them the system will not work.
Jul 04, 2017 | 2002 Chrysler PT Cruiser
My 2002 neon's A/C blows warm air. The vent pressure is working well- but it blows warmer than the outside air. Can I fix this myself? What might the problem be?
If you are handy, yes you can. Most likely causes are loss of freon which would prevent the compressor clutch from being engaged and operating the compressor, a lack of 12 volts being applied to the compressor clutch because the a/c compressor fuse or relay has failed, preventing the clutch from engaging the compressor, or the compressor clutch itself failing. Easy test is to watch the compressor pulley with the motor running. The pulley will, of course be spinning, but the circular assembly mounted to the front of the pulley will spin with the pulley only when the compressor is engaged. There is a sensor mounted to the a/c line that prevents the clutch from engaging the compressor if there in not enough freon in the system. You could go to auto zone or checker and buy a can of freon r-134 with a hose for around $15.00. It is fairly easy to follow the instructions to charge the system. If, after allowing some of the can to pressurize the system, the compressor clutch engages then you can continue to charge the system. Cold air should start to blow by the time the can is empty. Or you can locate the a/c relay located in the fuse panel, remove its plastic cover and manually close the contacts while observing the compressor pulley assembly. If the clutch doesn't engage then the problem in probably electrical, a fuse, the relay or the electric clutch itself. Go to auto zone and check you their dvd on a/c repair for under $9.00. Hope this helps! Dano
Jul 01, 2011 | 2002 Dodge Neon
Ac unit clicks outside but nothing engages fan or compressor on unit furnace still runs for heat setting and fan still blows but ac will not engage just hear a clicking was running for three days this...
Have you check the outside breaker? If its ok then you got a problem in your electrical system inside the unit probably the contactor is not engaging this is where the 24 volts from the thermostat calls for the 240 volts to run the condenser fan and compressor. Be careful checking this out because of the high voltage.
Jul 09, 2010 | Carrier 38CKC048 Air Conditioner
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!!
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Outside compressor unit not blowing. The solenoid
if fan is not on check to make sure gettion 230 v to unit the contactor is 24v controled by the indoor unit look at the capacitor to make sure not swelled up on top if so bad you can turn off power and jump around contactor if you feel it is pitted to bad to run unit most of time when bad they weld together a new one is adout 15.0 seperate wires with zip ties to not get mixed up also check wires at compressor they sometimes come off hopr this helps
Jun 04, 2009 | Ruud UBHC Air Conditioner
RUUD heat pump system does not cool properly.
With a heat pump system there are always going to be a back up heat strip inside the Air Handler.
If you detect a faint humming in the Condenser call your local service company and ask them to come and replace your capacitor in the condenser. The humming is from the contactor engaging but not being able to start the compressor due to not having the required Microfarads to start it.
Let me know if this helps
May 07, 2009 | Heating & Cooling
Amana PTC153D35AR Central Air Conditioner Logo
46 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
