Question about Car Audio & Video
Need to find full time positive and acc positive in an older hino that doesn't have the positive posts, like the new models
  • 973 Answers
Confirm that the vehicle is a "neutral or negative to earth. If its 12 or 24 volt. Get hold of a bulb with the same voltage with a socket and wires ( These can be bought as "test lights cheaply from any auto parts store) and connect 1 end to the body of the car (on bare metal or screw head) and the other end to the wire you are testing. If the globe lights straight away with the key off, then that's your permanent active, if it only lights when key is on accessory mode or engine run position, then that's the "switched active"
Posted on Oct 18, 2013
I have a 2006 hino my question is this is the third time in 2 month my Hino truck lost power they say we changed the fuse this time my truck lost power and the check engine came on
unlikely as a wiring harness problem will be constant
Ask what fault codes were reported and if they do not know , that would indicate that they are guessing
find another Hino service dealer and have the codes read first
Aug 29, 2017 | Cars & Trucks
Hcan i obtain an electrical wiring diagram for a hino bus modelrc3274a thank you
contact the manufacturer if it is a genuine Hino make. Most busses are just chassisis ( in this case Hino truck) on which a coach builder builds the cabin.In that case contact Hino on google ---technical division or customer service and quote the model and ask for the schematics. If it is a custom built by a coach builder ( plate somewhere near the door -dash -engine bay etc contact them and see if they can supply the schematics for the wiring that they do.
Jan 16, 2015 | Cars & Trucks
What is the hino jo5dt engine valve clearance
http://www.hino.com/trucks/story_810.php
Jo5DT diesel engine. (no year?)
second ever too ask an not one answer ever
even google , shows, ZERO.
well , time to buy the FSM book and read it up.
or go to hino and ask.?
May 08, 2014 | Cars & Trucks
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
Find a positive full time power and a acc positive
Usually modern cars have this wires in the DIN connector of radio slot, battery (yellow wire) & under key (red wire), if you need more power to powering an amplifier or other heavy electrical load you can connect a wire directly to battery positive pole, the negative can be connected directly to car chassis, be sure that the wires used for this last application are at least 4 mm of diameter.
Oct 14, 2013 | Car Audio & Video
Diagram of brake system on hino kl 340 series
go to www.automecanico.com translate this website amazing with your browser and fix it.
God bless you
Jul 17, 2013 | Cars & Trucks
98 expedition cranks when no one is in the vehicle and no keys are in the ignition
Hello, Start by looking under the hood at the starter Relay. Unplug the small wires and your starter should stop spinning. If it does not, then the Relay is bad. If it does not spin continue with the following steps.
You need to put a test gauge on the small wire you removed from the starter relay. You can test with a light or with a Voltmeter. Either way, your goal is to kill the current in this small wire. The small wire gets its power from a series of switches. The Ignition switch can be bad and may be providing full-time power.
Before you replace the Ignition switch, look under the Drivers' dash and see at the top of the brake pedal for another switch. These get hit and broken by feet all of the time. If the switch appears broken or out of place in its holder, correct that problem and observe if the test device shows no power to the small starter Relay wire.
You have diagnosed or fixed the problem and avoided pulling out a good Ignition switch. If the problem is still there, then you need to try a new Ignition switch. You will need to remove the plastic steering column cover and position the Ignition core to either ACC or RUN position to remove the key core. Remember to press under the switch to release a spring-loaded pin.
While you are attempting to remove the Ignition, the Battery will need to be disconnected several times. This is because the Interlocks need power to allow the key to turn, but you do not want full-time power while you have the key in ACC or RUN position.
I hope my Solution is very helpful to you. You should be able to repair your problem with what I have given you.
Aug 16, 2011 | Ford Expedition EL Cars & Trucks
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
