Question about Fisher and Paykel Dryers
Fisher and paykel DE45F56EW 1 FP AU runs but no heat... no error codes so how can I troubleshoot?
  • 50 Answers
Protector over load on heater needs to be reset
Posted on May 04, 2014
3 Suggested Answers
  • 686 Answers
SOURCE: Dryer is working but not heating up or drying clothes
bad heat element
Posted on Feb 20, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my fisher and paykel model
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 31, 2010
Fisher & Paykel ActiveSmart 517L Top Freezer E521TRX3 control panel lights blinking
Hello Ajay Gaddi...
Flashing panel...
I got NOTHING after reading several manuals
(seems to be a UK model... We have limited information here in the USA)...
Accept my apology and try these references
(as appropriate)
If after checking these points you still need assistance, please refer to your nearest
Fisher & Paykel Authorised Repairer, or contact us through our local website listed on the back cover.
In New Zealand if you need assistance...*
Call your Fisher & Paykel retailer who is trained to provide information on your appliance, or if we
can be of any further help, please contact our Customer Care Centre.
Toll Free: 0800 FP CARE or 0800 37 2273
Fax: (09) 273 0656
Email: customer.care@fp.co.nz
Postal address: Fisher & Paykel Appliances Ltd, PO Box 58732, Botany, Manukau 2163, Auckland.
If you need service...*
Fisher & Paykel has a network of independent Fisher & Paykel Authorised Repairers whose fully
trained technicians can carry out any service necessary on your appliance. Your dealer or our
Customer Care Centre can recommend a Fisher & Paykel Authorised Repairer in your area.
In Australia if you need assistance...*
Call the Fisher & Paykel Customer Care Centre and talk to one of our Customer Care Consultants.
Toll Free: 1300 650 590
Fax: (07) 3826 9298
Email: customer.care@fp.com.au
Postal address: Fisher & Paykel Appliances Ltd, P.O. Box 798, Cleveland, QLD 4163
Fisher & Paykel has a network of qualified Fisher & Paykel Authorised Repairers responsible for
servicing only Fisher & Paykel branded appliances. Our Customer Care Centre can recommend a
qualified Fisher & Paykel Authorised Repairer in your area.
In United Kingdom if you need assistance...*
Phone: (0845) 066 2200
Fax: (0845) 331 2360
Email: customer.care@fisherpaykel.co.uk
Postal address: Fisher & Paykel Appliances Ltd, Maidstone Road, Kingston, Milton Keynes,
Buckinghamshire, MK10 0BD
Aug 21, 2017 | Fisher Refrigerators
Hi, my machine won't fill with water
It would only be either cold or hot that does not work. Replace the Inlet solenoid under the top panel.
You can use the same aftermarket valves for both (Original FP valves are different, cold is wildly expensive compares to hot). http://www.ebay.com.au/itm/Fisher-Paykel-Cold-24Volt-Compatible-Inlet-Valve-Part-FP420148S-/130833870254?pt=AU_ApplianceAccessoriesParts&hash=item1e764e6dae&_uhb=1
May 28, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL15 error code 49
The 1.6amp fuse on the board would be blown along with the mosfet's that drive the water valves, not an easy task to replace mosfet's.
Best to get a new motor controller board,
Quote the 6 digit part number under the bar code to get the right part.
Mar 30, 2013 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel MW 512 AU is not running. The first and the last lights(long wash and spin leds) on the displays stays ON in red and keeps on beeping. I appreciate any help in resolving this issue
This(130) is the only code that comes close to that,
There is no code for 129.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 26, 2012 | Fisher and Paykel Washing Machines
My FP WA75T65GW1 7.5kg which I bought 6/7/10 is stopping at the spin dry stage
is there any status lights blinking indicating an error code ... open top console and remove tech sheet each indicator light blinking has a numerical value add each indiacator light together per tech shheet and that will give a total number and read error code
Jan 24, 2011 | Fisher and Paykel Washing Machines
Fisher Paykel control panel to far left side has a film on it that chipped off - showing a shinner stainless steal under it. I guess this is a coating of some sort. Dish draws are 4 1/2 yrs old. Mild det...
You can buys the parts that look chipped/ broken and replace them. Panel parts are very easy to replace.
Check out which parts you need from the parts manual and order from the local fisher and paykel distributor.
http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/DISHWASHERS/599084%20Dishdrawer-Version%203%20%20eg%20%20DD603%20etc.pdf
The parts that you need are listed from page 6.
Jan 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
No power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Jul 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Error code F32 for fisher paykel fridge F32 and a spanner is appearing in the display of our new Fisher Paykel fridge model # RF610ADUX. What does this mean ?
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Aug 24, 2008 | Refrigerators
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Open Questions:
Dryers Logo
77 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
