Question about Freezers
Auto defrost Waeco CR1140E caravan fridge
Supposed to auto defrost fridge compartment,how to do this?
Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the problem
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Oct 17, 2014 | Samsung Freezers
Frozen water on bottom of whirlpool model evl181nxtq01
I assume that the water is on the bottom of the fridge compartment? It could be that the drain trough has blocked and every time the fridge does an auto defrost, water runs out onto the floor of the fridge rather than down the drain. Once the defrost finishes, the water will stay on the floor of the fridge. Cold air falls to the bottom so its possible to get a sheet of ice in the bottom of the fridge. Locate the drain trough in the back wall of the fridge. See if you can visually locate any blockages or carefully dribble warm water down the drain to clear it.
Oct 19, 2013 | Whirlpool Freezers
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
Our 4 year-old Whirlpool Upright Fridge/Freezer model 2FHKXXKQ03 repeatedly trips out on the defrost cycle. We live on a small island in Moreton Bay Queensland and without any Island-based technical...
check the timer maybe your Fridge it has timer to defrost or is set to auto defrost try to make set to manually defrost..or if you have manual of that item read it for guidance..
Apr 02, 2010 | Freezers
Bosch fridge frezer
gas is sealed for life....sounds like it is auto defrost mode.leave switched on. after a full manual defrost. for at least 24 hours to settle down keep door shut... then check. should reset itself.make sure all vents,drains are clean.
Feb 14, 2010 | Freezers
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
Fridge won't get cold
You need to defrost it and remove rear panel in freezer compartment.After you defrost it pour hot water in the hole in the center rear area of freezer to make sure it is draining good.After that take down model# from the inside of fridge on the side .You will need a defrost timer You can use the model number and and your local parts depot will order it acourding to the model.80% of the time the fridge is iced up that is what is causing it;Hope i helped:) Let me know if there are anymore thing you want to know before you try
May 20, 2009 | Freezers
Auto defrost is not working on my zanussi ice free fridge /freezer
You have a defrost problem. It means you have 3 parts that can be involve ( timer, defrost thermostat, element) most of the time it's the timer. Hope it was helpful. :)
Francois
Aug 25, 2008 | Freezers
Fridge not cooling
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Sep 30, 2007 | Freezers
Freezers Logo
54 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
