My asid tech ps3 controller wont stop flashing
My PS3 wont turn on.
If there is no power check the adapter, if there is power then remove and keep aside so as to reset. If the unit does not switch it is possible that it needs a reboot.
To reboot L+R+start or hold the power button on till the psp resets
If this wont work please contact the dealer
Jul 05, 2012 | Sony Playstation 3 (PS3) Console
Gioteck vx1 wireless controller will not pair up to my ps3
This works: Turn ps3 on. Plug the controller into the usb cable and into ps3. Then plug the dongle into other usb port. After a short time the dongle will flash quickly (this means it's in pairing mode - when the dongle flashes slowly it's too late). Press the PS/Home button as soon as you see the dongle fast flashing. All the LED's on the controller will begin to flash and after a short time one (or two) will remain solid. Immediately disconnect the charging usb lead from the controller and again the LED's will flash, push the PS/Home button again and after a short time one or two will remain solid. The controller should now be working. If the controller fails to respond repeat this process but make sure that you disconnect the dongle and reinsert (so you can see the fast flashing lights and try again).
Jan 04, 2012 | Video Game Consoles & Games
My dualshock 3 controller wont connect to my ps3
i just got my new sony dualshock 3 controller (Japanese white version, i dont know if that matters) and when i try to connerct it without a USB the 4 lights will just flash and evenually just stop as if there was no ps3 there. If i connect it with a USB it will look as if it has connected, the ps3 will think it has but there is no input form the controller and instead of the first light going on the first and the second will go on. if anyone can give me any sort of help that would be great.
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
Trying to connect to a ps3. Lights flash but wont sync
plug the controller into the ps3 and then try it..... a lot of times if you unplug the ps3 it wont recognize the controller next time you turn it on this should help
Apr 14, 2009 | Sony Wireless Controller for PS3
Ps3 controller going nuts
Hi..
If it were mine..I'd get a ziplock bag big enough to put it in and soak the thing in 91% or better alcohol..Slosh it around a bit let it set for a few hours..drain it and let it dry out for a day or so.
Other than that..Buy a new/almost new one.
Jan 15, 2009 | Sony Playstation 3 (PS3) Console
Controller still wont work
Hmm. I think i'll need a bit more info please.
When you reset your PS3 and the system's light goes red and you hit the PS button your controller the four lights just flash? Is that right? The only time your controller will "connect is when you plug it in with USB?
Try this. Turn your PS3 on. Press the reset button on the back of your controller and hold it for a few seconds, then press the PS button to see if it connects then. If it doesn't you could try removing the internal battery from the controller and putting it back in. That might clear up any settings that were saved in it.
Let me know how it goes.
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
CONTROLLER PROBLEM
Try resetting your Controller. Using a paper clip, there is a small reset button on the underside of the SIXAXIS. Press it.
While your PS3 is still on, press the PS button on the controller.
Dec 09, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
