Question about Pool & Spa
Ao smith c48l2pa105 what's the bearing size - Pool & Spa
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
  • 24 Answers
SOURCE: capacitor wiring on a ao smith M#-C48L2N134B1.
The single lead goes to one leg, the split wired leg in the same spade goes to the other. They are usually yellow wires. As far as Hayward, Jacuzzi and Starite are concerned.
Posted on Dec 17, 2009
  • 100 Answers
SOURCE: Is it possible to replace the bearings on a AO
any good electric motor shop should be able to
Posted on Feb 14, 2010
al_kupchella
  • 843 Answers
SOURCE: I have a A.O Smith 2 HP motor. Is there any way I
Sorry, but no. Reversible AC motors are very different. Without that design difference (which adds cost) you can't reverse it. Your label is telling you that you don't have the special kind of motor.
Posted on May 14, 2010
MOTORWIZJ
  • 1339 Answers
SOURCE: where to find replacement parts for AO smith pool pump motors
TRY YOUR LOCAL POOL PUMP MOTOR REPAIR GUY... NEW ARE HARD TO FIND AND CRAZZZY $$$ HE WILL HAVE GOOD USED PARTS CHEAP . IT'S THE GREEN THING TO DO. FIX -REPAIR.. GOOD FOR YOU, I'M PROUD OF YOU.. GOOD LUCK AND VOTE FOR ME...JAY
Posted on Aug 23, 2010
What size bearings does AO smith motor 8d-10-1n11cb use
better off replacing whole motor or pump if bearings bad soon seals because they got hot less headache replace whole pump
May 27, 2016 | AO Smith Pool & Spa
What bearings I need for AO Smith century 3.6 HP part 186364
cannot buy bearings for motor must replace motor dont forget seals
Feb 26, 2015 | AO Smith Pool & Spa
Lubricate ao smith motor
If there's no grease fitting (ball bearings), remove the endbells and manually force grease into the bearings. On sleeve bearings use oil (2in1 oil is ok).
Dec 08, 2013 | A.O. Smith Heating & Cooling
Ao smith c48l2pa105
It can be rebuilt or replaced. Parts are available at: http://www.inyopools.com/Products/00200017003493.htm
I am assuming it pumped some water to the sprinklers and the pump is not frozen. If so then It sounds like either the start capacitor (I did not see it in the picture) or possibly the start switch has failed. That motor comes with a 1 year warrenty.
Aug 24, 2013 | Plumbing
Need replacemant bearings for 1 hp AO Smith pool pump motor
6203 2rs c3 are the bearing you need. best to have a pro do it. should cost around $75, thats what I charge /w free shaft seal. remember to prime the pump after any repair
Mar 27, 2013 | AO Smith 1 hp 3450rpm 56J Frame 115/230...
Oil a ao smith motor
no way to lubricate unless oil hole on shafts
Oct 27, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
AO Smith C48l2pa105 WIRE DIAGRAM
read the wiring lay out on the motor
Jul 13, 2012 | AO Smith C48l2pa105
How to replac bearings in century pool & spa motor
if bearings are bad motor overheating and ruining seals replace whole unit less hassle
May 10, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Is there a start cap on an ao smith 177450? The external run cap is fine, but the motor is humming, won't spin. 1HP 1.65SF, I think wired for 115V but not 100% sure on that. Thankyou!
Check your bearings and the impeller. There is a start/run cap ... and that may be the trouble. Be careful while working with a capacitor. Check the bearings and impeller first.
Oct 17, 2011 | AO Smith Pool & Spa
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
Pool & Spa Logo
73 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
