Sony Grand Wega 55 inch LCD Projection TV, the red light in the ffront keeps flashing "6" times, and the TV won't turn on.
  • 41 Answers
6 blinks is an indication of a missing voltage. It's not the lamp or balast. It may be an indication of a thermal or heat trouble. These sets have thermal protection because of the heat created by the lamp. The thermal fuse may have opened. If this has happened you should have professional check it out. This set has 3 or 4 fans. These should be checked out or replaced. I suggest a Sony authorized repair. This is not a repair I would recomend for you to attempt. This set keeps a record of it's falures and the pro can check for any other trouble also.
Posted on Apr 24, 2009
Thermal fuse issue?
Posted on Jul 23, 2013
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
I have a 55" sony
According to the manual (you can see it here) page 122 that describes 3 red flashing lights:
"The lamp cover is not attached securely. When you secure the lamp cover, the POWER / STANDBY light flashes in red and the LCD projection TV enters the standby mode (see page22)"
Page 22 says:
"... if the POWER / STANDBY light flashes continuously, this may indicate the display unit needs servicing..."
Most DLP displays make use of a "color wheel". These small motors spin at many thousands of RPM. They often begin to make scratching sounds when they are beginning to fail. Some manufacturers make it difficult to change yourself - and others make it pretty easy.
I hope this was at least a good starting point for you & good luck. Please rate my reply. Thank you.
Apr 04, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
My tv won't turn on anymore. The red light flashes 6 times then pauses for a couple seconds then starts flashing six times again. Just keeps doing it repeatedly
try unplugging the tv and waiting a minute and try it again if its still the same? It sounds like a Capicitor problem on the Power supply.
Dec 26, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Standy Light Flashes 6 times when I turn the TV on.
First thing I would try is the micro switch on the lamp door. The doors get overheated and warp pushing away from the switch. The micro switch shows the tv an open door and wont let the tv start. Depending on the model you have the lights mean different things but on a WEGA rear projection LCD it ususaly means a board has failed. I just had this problem on a KDF-60XBR950. The C2 digital board was bad. Good luck
Jul 31, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
60 inch sony wega lcd projection
Possible themal sensor. Easy to bypass too!!! Check with authorized Sony repair facility.
Dec 17, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
886 people viewed this question
Top Televison & Video Experts
Electro Med Services...
