Question about Gateway Profile 5XL PC Desktop
Monitor in power save mode
Turn computer on goes into power save mode try to clear cmos no luck same problem
    Problem Solver:
  • 9 Answers
Man is your machine booting.????
if the machine is booting and no display on the moniter then check the power to the moniter ..... if ok
then if you r using xp os the
go to contol panel >Power options>Power scheme > select always on
Good Luck !!!!!!!!!
Posted on Apr 24, 2009
WEDWA
No signal on monitor, keyboard num key not on/off CPU is running
some bios problem try reset bios given method
The easiest way to clear the CMOS is to enter the BIOS setup utility and choose to "Reset BIOS Settings" to their factory default levels
Yet another way to clear the CMOS is to reseat the CMOS battery. By removing and then reinstalling the CMOS battery, you remove the source of power that saves your computer's BIOS settings.
apply any method and try
May 19, 2012 | Computers & Internet
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
Monitor stays in standby mode(power save)
If the monitor will not power up to give an image on the screen, try to connect it to another computer and see if it works. that will eliminate hardware failure of the monitor.
Check the vga cable connection from the computer graphics card to the monitor and make sure the connections are tight.
Then test the computer with a known working monitor, if it fails to work, the graphics card on the computer is at fault.
If replacing the graphics card does not work, try clearing the CMOS on the computer.
Jun 20, 2011 | Dell Computers & Internet
My PC desktop is in power saving mode, how can i put into normal mode?
This is what i do whenever someone asks me to remove their PC from power saving mode.
Follow there
Try clearing the NVRAM as follows:
-Turn off the computer
-Disconnect the monitor.
-Unplug the computer.
-Take out the video card.
-Remove the CMOS battery for a couple of minutes.
-Insert the battery.
-Connect the video card and monitor.
-Turn on computer.
Apr 05, 2011 | E-Machines eMachines Desktop PC
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
My main home computer whener turned on goes to analog powersaving
LG does not show the 1750 monitor on their web site. It did show some discontinued monitors including a 1752, but there was no information available about them.
Another LG site said to use the far right bottom to auto adjust....for another monitor.
My HP has four buttons, MENU, <, >, and Return (also AUTO). Menu opens the monitor dialog box, with the arrow bottoms shifting through the menu. Select an item with return, then arrow to your selection, menu is also your exit button.
You may have a power saving selection here.
Also check the control panel for the POWER OPTIONS properties. A power scheme selection here will also change the mode of your monitor.
good luck
Feb 18, 2010 | LG Flatron L1750S 17" LCD Monitor
Computer screen goes into "digital power saving mode"
You should be able to adjust the settings on the monitor to prevent it from going into power save mode, or at least to delay how long it takes before it goes into power save mode. Press the menu button and look for settings that might disable or change power save mode.
Also, does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your newer monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PC's video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG L1915S 19" LCD Monitor
Monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Feb 22, 2008 | Dell Dimension 4600 PC Desktop
When I try to start my computer it automatically goes to power saving mode.
Take the side of pc off and locate CMOS battery, 3V disc shaped, and check if not flat as your pc will not start at all if it has lost all settings in bios. If replaced battery and still no luck locate on motherboard 'JBAT1' terminal and put jumper on pins 2-3 then back on pins 1-2. This will clear any faulty cmos settings and require you to set time and date again etc. If you still get no boot up, either the power supply or proccessor is faulty; unfortunately hard to diagnose over the net.
Dec 25, 2006 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Gateway Profile 5XL PC Desktop Logo
192 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
