My closed captioning is getting cut off
The closed captioning at the bottom of the tv are getting cut off. i have tried to change the picture settings but they are all still cutting of the closed captioning. help please?
  • beyondsat May 11, 2010
    Is this an HDTV? Do you use a satellite or cable box? Do you use your satellite or cable box for your CC or do you use the TV?
    Genius:
  • 1,039 Answers
Are you changing the format or picture size. Some times marked zoom on the remote. Are you using a cable box or SAT recever. These boxes also have setting for format change.
Posted on Apr 25, 2009
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Black square on screen of 19 inch TV
Check your closed-caption settings and be sure they are turned off. If captioning is set for text mode you can have this trouble. The TV blanks out a part of the screen for the text it never gets to display. Once captioning is shut off (or set for normal caption mode if you want to use it) the black box will be gone.
Feb 04, 2009 | Konka K1938U 19" TV
Can't get the closed caption on my orion 13 inch tv
you need original remonte control to do that if in the front panel of your tv dont have menu button
Dec 09, 2008 | Televison & Video
Black box in middle of screen
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
Picture within a picture on screen
Click here to find info the user's guide and how to turn close caption OFF. Download all the files and and you should find the info on page #19 but you will need to have the TV remote control or if your TV has a menu/set up button on the front panel, you can try to get to close caption using the channel up/down and volume up/down.
Good Luck.
Oct 10, 2008 | Sony KV-35V35 TV
Close captioning
Well lets try the simple things first, Go to the TVs menu using the original TV remote and find the icon or menu that says Captions, in that menu turn all the closed captions OFF. Second there is a button on the original TV remote that says format, push this till you get to a screen that says FULL in the upper left corner. That should resolve your problems, If closed caption still comes through then we need to know if this set is hooked directly to cable or goes through a cable box. It sound like you simply had the closed caption turned on and the screen in one of the zoom formats this TV provides
Mar 07, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Nov 14, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
How to get rid of a black screen on my tv. sound is ok
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
Jul 07, 2007 | JVC AV-27530 27" TV
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
Open Questions:
Televison & Video Logo
245 people viewed this question
Top Televison & Video Experts
