Question about Kodak Easyshare C813 Digital Camera
When i turn my camera it says lens error 126,0,0
Ok i have of course a camera i turned it off then it stoped working it just lets me see my pics on my favorites if tried everything how do i fix it
  • 56 Answers
There is a problem with your lens section, no one is repair it with our opening it. So please get it repaired with your company professionals only.
Posted on Apr 24, 2009
My canon powershot won't let me download pics to my computer. when i turn it on, it says lens error, restart camera, and then turns off by itself
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 30, 2010 | Canon PowerShot SD1100 IS Digital Camera
Turn camera off and on again -- fried in outlet
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
May 22, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Nikon S220. Lens error. Turns on but displays lens error only.. Cannot take pics
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 15, 2010 | Nikon Coolpix 2200 Digital Camera
Lens error 126, 1, 0,0
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 05, 2009 | Kodak EasyShare C633 Digital Camera
Camera wont turn on due to lens problem....
Same problem. I applied pressure to the extended lens by slightly twisting it from side to side. Hit the power button and the lens retracted and then extended again. The camera seems to be working properly.
Jan 26, 2009 | Kodak Easyshare C813 Digital Camera
Lens Error 126 01 000
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 25, 2008 | Kodak EasyShare C613 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Error 99
i had the same problem and i found this guide online fixed my problem
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
Apr 19, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Lens error
i had this problem i turn my camera on the lens came out i turned them then my camera stop sayind lens error but now my pic is not clear
Jan 06, 2008 | Nikon COOLPIX L4 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
118 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
