Question about Texas Instruments TI-82 Calculator
8.23x10 negative 6 power - Texas Instruments TI-82 Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press 8 . 2 3 2nd [EE] (-) 6
Posted on Jun 01, 2014
Need color code for 16 pin connector, power plug
Pin Number Wire Color Function 1 White Left Front Positive 2 Green Left Rear Positive 3 Violet Right Rear Positive 4 Grey Right Front Positive 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front Negative 10 Green/Black Left Rear Negative 11 Violet/Black Right Rear Negative 12 Grey/Black Right Front Negative 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
Sep 18, 2015 | JVC KW-AVX706 Car DVD Player
I am trying to calculate 6.67 x 10 to the -11 power and cannot figure out how to make a negative power of ten work.
Make sure you use the (-) key just to the right of the decimal point and not the - key above the + key.
Press 6 . 6 7 2nd [EE] (-) 1 1 to enter the number.
Dec 14, 2012 | Texas Instruments TI-30 XIIS Calculator
How do i raise a number to the negative power for example 1.00625 to the -360 power
1 . 0 0 6 2 5 y^x +/- 3 6 0 =
+/- is the key just to the right of the decimal point key.
Jul 18, 2012 | Sharp EL-501WBBL Calculator
I am trying to multiply in scientific notation but I don't how to do it when the power of 10 is a negative i.e 1.67 time 10 to the 21st power multiplied by 9.11 times 10 to the -31 power. thank you
Make sure you use the +/- key just to the right of the decimal point key when entering negative values, including exponents.
1 . 6 7 EE 2 1 * 9 . 1 1 EE +/- 3 1 =
Aug 30, 2011 | Texas Instruments TI-30XA Calculator
How do i type a negative exponent into the calculator? i.e. 4 to the negative second power.
4 ^ (-) 2
The ^ key is just above the divide key, the (-) key is just to the right of the decimal point key.
Aug 21, 2011 | Texas Instruments TI-84 Plus Calculator
What is 9 to the 2nd power plus -7 to the 3rd power plus -6 to the 2nd power x 5
I never know if these questions are serious, but I'll play along.
Remember the definition of a power: it's a number multiplied by itself that many times. For example, 4 to the 3rd power (4^3) is 4 X 4 X 4, or 64. So the problem you list can be written
9^2 + (-7^3) + (-6^2) + 5, or
9 X 9 + (-7 X -7 X -7) + (-6 X -6) + 5
Don't forget that negative X negative = positive when multiplying.
81 + (-343) + 36 + 5 = -221
Mar 16, 2011 | Computers & Internet
Thanks for your help. But I dont see any text explaining cable/connector for, only these was there: ''4-6 Power switch'', ''+2-1 HD_Led'', ''+5-1 SUS_Led'', ''+3-1 Power_Led'', nothing more. How do I know...
where you see the + next to " +2-1 HD_LED" this means that the connector for the hard drive LED should be plugged onto pins 1 & 2, and that the " color " part of the conenction should be on pin 2, because pin 2 is your positive lead...
4-6 Power switch - Does not matter wich way it is plugged in, as long as it's plugged onto pin4 and pin6
+2-1 HD_Led - Hard drive LED - Pin2 is positive, pin1 negative
+5-1 SUS_Led - suspend LED - Pin5 is positive, pin1 negative
+3-1 Power_Led - Power LED - Pin3 positive, Pin1 Negative
Jun 21, 2009 | Intel 865G Motherboard
98 corvette 5.7 eng., harmonic balancer needs replacing!
Crankshaft Balancer: Service and Repair
REMOVAL PROCEDURE
1. Disconnect the negative battery cable.
2. Release the accessory drive belt tensioner (3).
3. Remove the drive belt (5) from the engine.
4. Remove the power steering gear from the vehicle.
5. Remove the starter motor.
6. Remove the power steering cooler bolts from the front crossmember.
7. Remove the power steering cooler from the front crossmember and reposition.
8. Release the air conditioning (A/C) belt tensioner (10).
9. Remove the A/C drive belt (1) from the engine.
10. Remove the crankshaft balancer.
INSTALLATION PROCEDURE
1. Install the crankshaft balancer.
2. Install the A/C drive belt (1) to the engine.
3. Install the power steering gear.
4. Install the power steering cooler to the front crossmember.
5. Install the power steering cooler bolts.
^ Tighten the power steering bolts to 11 Nm (97 inch lbs.)
6. Install the starter motor.
7. Lower the vehicle.
8. Install the accessory drive belt (5) to the engine.
9. Connect the negative battery cable.
^ Tighten the negative battery cable bolt to 15 Nm (11 ft. lbs.).
10. Program the Transmitters.
May 11, 2009 | 1997 Chevrolet Corvette
Can't get A/C belt around pulleys on my 01 Chevy Tracker 2.5 V6
Removal & Installation
1.6L Engine
A/C Compressor Belt
  2. Loosen the A/C compressor mounting bolts.
  3. Pivot the A/C compressor towards the engine in order to relieve the tension on the belt.
  4. Remove the A/C compressor drive belt from the pulleys.
To install:
  1. Properly route and install the A/C compressor drive belt on the A/C compressor, the power steering (if equipped), and the crankshaft pulleys.
  2. Adjust the A/C compressor drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the A/C compressor mounting bolts to 13-20 f t. lbs. (18-28 Nm).
  4. Connect the negative battery cable.
Alternator Belt
  2. Remove the power steering pump and the A/C compressor drive belt.
  3. Loosen the generator mounting bolts.
  4. Pivot the generator towards the engine and remove the accessory drive belt.
To install:
  1. Properly route and install the generator drive belt on the pulleys.
  2. Adjust the alternator drive belt to obtain 6-8 mm (0.24-0.32 in) deflection for a used belt or 5-6 mm (0.20-0.24 in) deflection for a new belt.
  3. Tighten the generator mounting bolts to 17 ft. lbs. (23 Nm).
  4. Install the power steering and the A/C compressor drive belt.
  5. Connect the negative battery cable.
Power Steering Pump Belt
  2. Loosen the power steering pump mounting bolts.
  3. Pivot the power steering pump towards the engine in order to relieve the tension on the belt.
  4. Remove the power steering pump drive belt from the pulleys.
To install:
  1. Properly route and install the power steering pump drive belt on the power steering pump and the crankshaft pulleys.
  2. Adjust the power steering pump drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the power steering pump mounting bolts to 22 ft. lbs. (30 Nm).
Apr 26, 2009 | 2001 Chevrolet Tracker
Texas Instruments TI-82 Calculator Logo
23 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
