Question about Kenmore Sewing Machines
Clutch does not engage on kenmore 1914 sewing machine
SOURCE: Bobbin won't wind
I also have the 15358. You probably forgot to "lock" the bobbin winder. After you put the bobbin case on it's peg, push the peg to the right until you hear a click. Then after you disengage the clutch, the bobbin will wind.
Posted on Feb 15, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 980 Answers
SOURCE: clutch won't release.
This what you do, get a wide blade screwdriver, place the screwdriver blade on one of the slots or grooves on the stop motion wheel on the left hand side as you look at the machine from the end, the the top of the handle a good thump and you will find it will release, don't over tighten once you have freed it off.
Posted on May 29, 2009
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
  • 1116 Answers
SOURCE: my kenmore sewing machine won't wind the bobbin
Not all models are the same.
You will have to refer to the manual to see what needs to be engaged or disengaged.
On some machines, this is loosening the center knob on the handwheel and moving the bobbin pin to the right or the winding knob to the left.
There are threading/bobbin winding guides sewusa.com where you may find your model or one that is similar.
Posted on Mar 21, 2010
Kenmore sewing machine model 158-17031- motor runs well but think the clutch or something is stuck
Has it been oiled lately? If not, it could be seized. Old oil turns to glue and then varnish unless it is regularly maintained. Make sure to use only fresh, good quality sewing machine oil or liquid Tri Flow Synthetic Lube. Slowly rock the hand wheel and apply a couple drops every place where metal rubs against metal--no oil on belts, rubber, synthetic parts! If it is still resistant, direct hot air from a handheld hairdryer into the internal mechanism and repeat the process until things are loosened and moving smoothly again.
A sewing machine should be cleaned and lubed every 40 hrs of working time or every 6 months if not in use.
Oct 03, 2016 | Kenmore Sewing Machines
Kenmore 158-12112 sewing machine, the clutch is not engaging, sometimes it does and sometimes it stops engaging
Have you tried a thorough oiling with good quality sewing machine oil--every place where metal rubs on metal? NO belts, plastic, or other than metal parts. Old oil tends to stick parts together preventing them from moving.
Jun 03, 2016 | Kenmore Sewing Machines
What year was singer sewing machine serial number g3453709 was manufacture
G-2.574.401 to G-3.423.850 (1913)
G-3.423.851 to G-3.903.500 (1914)
That should give you the range. Likely 1914
Sep 21, 2014 | Singer Sewing Machines
Trying to find replacement bibbon case for Kenmore Model 1914
Hello Victoria, It appears that the bobbin case you need is extremely common. There are several venders on EBAY that can hook you up with a new bobbin case for under $10.00.
Mar 23, 2014 | Bernina Sewing Machines
How to install a Kenmore monogramer to a Kenmore zig zag machine
You are replacing the presser foot with the monogramer and you will need the very specialized instructions for it's proper use.
Jan 30, 2014 | Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
The clutch is not engaging (it seems).. The wheel doesn't turn which in turn means it is not stitching. Haven''t used it in 6 months, but it was fine the last time I used it.
This may seem like a stupid answer but did you push in the knob. If you were winding bobbins last time you used it you may have forgotten to re-engage the clutch.
Jan 12, 2011 | Kenmore 11101 Mechanical Sewing Machine
I have a Kenmore 1914 and it still works graeat
If you mean the foot control, overheating MIGHT be due to the motor having too much load. This could be due to lack of lube of the machine or any other thing causing excess friction.
These controls normally get warm, but not to the point of smoking unless they get loaded with dust.
Nov 23, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
59 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
