Question about Lexmark 4427-003 X3430 All-In-One Color Inkjet Printer Usb P/N: 4427-0
Print cartridge number forvlexmark model 4427-003
Incompatible print cartridge
check the product where its manufactured, some models launched USA & Asian countries in same model numbers with different number cartridges, no problem with the printer because its detecting the existing cartridge replace with same cartridge...Vinay...
Sep 05, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
The alignment both vertical and horizontal are off!
Title: How to Install/Change the Print Cartridge Document ID:HO46 Back To Answers Properties 1000 Color Jetprinter 1100 Color Jetprinter 2030 Color Jetprinter 2050 Color Jetprinter 2070 Color Jetprinter 3000 Color Jetprinter 3200 Color Jetprinter 5000 Color Jetprinter 5700 Color Jetprinter 5770 Photo Jetprinter 7000 Color Jetprinter 7200 Color Jetprinter Lexmark X63 Lexmark X73 Lexmark X83 Lexmark X84 Lexmark X85 Mac OS 8.6 Mac OS 9.x.x WinWriter 100 WinWriter 150c Z11 Color Jetprinter Z12 Color Jetprinter Z22 Color Jetprinter Z25 Color Jetprinter Z31 Color Jetprinter Z32 Color Jetprinter Z34 Color Jetprinter Z35 Color Jetprinter Z42 Color Jetprinter Z45 Color Jetprinter Z45se Color Jetprinter Z51 Color Jetprinter Z52 Color Jetprinter Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How do I align ink jets?
      3. Click OK.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
About 2 years ago, I purchased a Samsung laser printer, model number ML-2510. It performed very well until about a month ago, when I put in a new cartridge, number ML-201003/SEE which was different from...
/SEE is the cartridge for the European version of the printer, /XAA is the version for the U.S. I can't imagine why it doesn't work, but there's a reason for the European designation..
Jul 20, 2009 | Office Equipment & Supplies
No Print Cartridge error displayed. I just put a new OEM Cartridge in and still displaying error.
If your get a No Print Ctgs chances are your connector in the rear could be damaged or you may need to do a reset in the service mode, since you never mentioned the Manufacture or the Model number, I do know to assist you further, So what is the make and model number of your unit ?
Mar 02, 2009 | HP Office Equipment & Supplies
Print Cartridge Error
Have had much experience with HP AIO models and would try to double check the contacts on the cartridge carriage.. sometimes a q-tip swap dipped in alcohol gently over the contacts will fix this - also note the dates on the ink cartridges (even the new ones) If the dates are previous to the date showing on the machine, this will give this error, but can be worked around by clearing the memory with a factory or full (hard) reset that sets everything back to zero dates. THis usually involves holding down certain button combos while plugging the machine in... Try a search for reset codes on HP site or google with model number and "reset code" to find the proper button combo.
Jan 08, 2009 | HP PSC 1410v All-in-One Printer
How to change lexmark Cartridge
      3. Click OK.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
is this a pc or mac?
for windows general make sure you folowed these steps:
      3. Click OK.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Color Cartridge error messages requiring replacement every few months
Issue The message Insert color Cartridge displays on the control panel of the product. This error usually occurs when the print cartridge or the print carriage contacts need cleaning, or when a remanufactured or refilled ink cartridge is being used. Solution To resolve the issue, follow these steps in the order given. Step one: Remove the print cartridge
  1. Turn the product on.
  2. Open the product to access the print cartridge.
  3. After the print carriage (the part that holds the print cartridges) stops moving, unplug the power cord. NOTE: Do not use the power button to turn off the product because the print cartridge will not be able to be removed.
  4. Remove the color print cartridge.
  5. Make sure that the part number on the cartridge is the correct part number for the product.
Step two: Clean the cartridge contacts
  1. Lightly moisten a cotton swab or lint-free cloth (like a coffee filter) with distilled, filtered, or bottled water. CAUTION: Tap water may contain contaminants that can damage the print cartridge.
  2. Clean the electrical contacts of the cartridge with the swab or cloth. Figure 1: Electrical contacts c00055424.jpg
  3. Wipe the contacts with a dry, cotton cloth to dry the contacts and finish cleaning. Figure 2: Wiping the contacts c00055425.jpg
  4. Reinsert the cartridge and lock it in place.
  5. Close the product and plug in the power cord.
  6. If the error message continues, repeat the steps to clean the cartridge contacts once more.
Step three: Clean the print carriage contacts
  1. Lightly moisten a cotton swab or lint-free cloth (like a coffee filter) with distilled, filtered, or bottled water. CAUTION: Tap water may contain contaminants that can damage the print cartridges.
  2. Remove both print cartridges in order to access the print carriage contacts.
  3. Clean the electrical contacts of the print carriage with the swab or cloth. Figure 3: Cleaning the carriage contacts (the model might look slightly different) c00130268.jpg
  4. On models equipped with locking latches, lower the latches. Figure 4: Latches in the lowered position (the model might look slightly different) c00055427.jpg
  5. Wait five minutes for the contacts to dry.
  6. Plug in the power cord. The product will begin to reinitialize. Wait until the process is complete before proceeding.
  7. When prompted, reinsert the print cartridges and then close the product.
Step four: Replace the print cartridge Replace the print cartridge indicated by the error message. If the error message continues, replace both cartridges. NOTE: If using refilled or remanufactured cartridges, or non-HP cartridges, replace them with new HP cartridges . HP cannot guarantee that refilled or non-HP cartridges will function correctly in HP products. If a new HP ink cartridge is defective, return it to the place of purchase with the receipt, or contact HP to obtain a replacement. Step five: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The error message could display for one of the following reasons:
  • Even if the cartridge is new, it might need to be cleaned. Print cartridges have a substance on the contacts to keep them from corroding during storage. This substance may cause poor electrical contact between the print carriage and the print cartridge.
  • The cartridge that is indicated in the message might not be the one that is causing the failure. The cartridges are electronically connected through the printed circuit board.
Apr 22, 2008 | HP PSC 2355 All-In-One InkJet Printer
Lexmark 4427-003 X3430 All-In-One Color Inkjet Printer Usb P/N: 4427-0 Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
