Question about Whirlpool Gladiator Refrigerator
Whirlpool fridge ice build up - Whirlpool Gladiator Refrigerator
  • 833 Answers
SOURCE: Whirlpool 635
Fully defrost your unit. This takes about a full 2 days with the doors open and unit off. Clean and repair all door gaskets. Avoid leaving doors open or introducing large amounts of moisture into the unit. This will probably take care of it. If not, let me know.
Posted on Dec 22, 2007
louislevel_2
  • 374 Answers
SOURCE: Whirlpool Side by Side Freezer - Ice Build Up in Drain
hi there,
common problem,several factors can be check,check your thermostat setting it maybe too low or you have defective thermostat,if you have good thermostat otherwise the refrigerant charge is to low there could be leak on tube,check your amper rating using clamp ammeter if you got low amper rating recharge freon,but why has low refrigerant there might be leak,repair the leak,before you recharge.hope this solve your problem have a nice day
Posted on Jul 21, 2009
  • 56 Answers
SOURCE: ice build up on freezer door
your door gasket isnt set right call for warranty service
Posted on Jun 03, 2010
heatman101
  • 43501 Answers
SOURCE: MY Whirlpool Model: 6EDFHKXKQ06 side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Feb 03, 2011
  • 132 Answers
SOURCE: I have an upright Whirlpool
It sounds like the auto defrost cycle has stopped working.
Manually defrost the freezer.
If things work better then it is the defrost cycle which is faulty.
A technician can help you with that
Posted on Apr 01, 2011
Whirlpool fridge WF258 freezer works perfectly; but fridge is in room temp, not working at all,light is ok
Damper door between freezer and fresh food not opening or build up of ice not letting cold air in fresh food side may have a defrost problem if you have a lot of ice on back wall of freezer
Nov 20, 2016 | Whirlpool Refrigerators
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
I have a whirlpool Gold Model GR2SHKXKS01. My problem is ice build up under the bottom tray of freezer and when fridge defrost the tube is frozen solid and creates this build up. After cleaning all the ice...
I have Ice build up under the tray in the freezer which makes water run into my refig and makes a mess what would cause this is the evavorator motor out?
Jun 03, 2009 | Refrigerators
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Gladiator Refrigerator Logo
18 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
