Question about Sharper Image SO227 CD Shelf System
Sharper Image Cd shelf system model # SO227
The system is plugged into a power outlet but ther is no display the standby light doesn't even come on, nothing works no power or sound. I love this system and it is no longer sold, is there anything that IO can do to fix the problem.
  • eblow Sep 25, 2007
    Please Help!
  • eblow Oct 04, 2007
    dukic, How do I check the fuse in the system?
    New Friend:
The one I troubleshot had a bad 4700 uF 25v capacitor next to the dc connector on the main pc board. this dc connector cable runs from the rear cover of unit(the rectifier board).When I power up the unit,dead,no standby lite no power.I removed all connections to cd board and just left the mmain board and display board connected.clock and standby came on,but after about two minutes the 4700uf 25v power cap started to smoke (and dmm read 12v and falling across cap).hurray that was my big clue! Replaced cap with a gang of 5 1000uf 35v nichicon electrolytes in a parallel L package formation to fit the realestate of old cap and allow cover closure.happy tunes.Unfortunatly made by cheapos who spec counterfiet electrolyte formulated caps.Watch out for "S.I." brand electrolytics.Check temp of rest of caps while running unit as this beast is chock full of them.
Posted on May 28, 2010
  • 93 Answers
Check is there power in outlet. If there is, check the fuse in system.
Posted on Oct 04, 2007
  • Anonymous Oct 05, 2007
    I'm not familiar with this particular system, but you should check with multimeter step by step from power cord where you loosing power. That will tell you which part is problematic, and that's step closer to solution. Be careful to avoid electric shock!!!
SOURCE:
Sharper Image SA255 cd door would,not work, got frozen, not able to close it even manually
This could be due to a mechanical failure in the door mechanism, BUT I had a 3-disc unit on the bench recently and the control logic was messed up. Try the reset and check to see whether it specifies the drive you are having trouble with as the one to be loaded
Nov 25, 2012 | Sharper Image SA255 CD Shelf System
I have a Sharper Image Power Tower 200 and I don't know where to plug in the power cord. Thank you.
On the same side were the turning knob is located, all the way down under the base there is a very subtle slot to plug in your cord.
Aug 13, 2011 | Sharper Image Power Tower Motorized DVD...
Cannot get my new crosley out of standby mode. which button do you push as there is no standby button?
When it is off and plugged into the wall outlet the standby light will be on. The stadby light will go off when power button is pressed. If not there is poblem that needs service.
Dec 26, 2010 | Crosley CR78CD-P CD Shelf System
Unit does not turn on or display time
do you mean a power surge, if so the surge may have overloaded the elctronics,=cooked ,so afraid is u/s
Jul 07, 2010 | Fisher SLIM-3010 Shelf System
Disc belt needed
You need only measure the diameter in MM and put that and "CD/Cassette drive belt" into google and you should find a supplier. A few MM either side shouldn't make difference. Drive belts etc are none specific makers by the way.
May 31, 2010 | Sharper Image SA265 Shelf System
Instruction book for a micro cd shelf system
not solved - but not going to pay for an instruction book when it should be a 'downloadable' item by sharper image
Dec 03, 2009 | Sharper Image SO330 CD Shelf System
Sharper Image 3-CD model SA248 Doors opening problem
The bands that allow the cogwheels to turn, snap and needs to be replace.
Sep 10, 2009 | Sharper Image Audio Players & Recorders
How to take apart a sharper image cd power tower?
Take a flat blade screwdriver and gently push in the center tabs of any CD slot. This might take a little while but once done the CD track will come apart and you will have access inside to the motor, gears and belt.
Jun 14, 2009 | Sharper Image Power Tower Motorized DVD...
Sharper Image SA260
activate the reset button on the back of the unit (you'll need something like a toothpick or a needle to do this) this should do the trick (it did for me) hope this helps
Jun 16, 2008 | Sharper Image SA260 CD Shelf System
Sharper Image SO227 CD Shelf System Logo
402 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
