Question about Craftsman Garden
Craftsman lt1000 lawn tractor md 917.272670 RUNS FINE THEN SURGES AND STALLS
5 Suggested Answers
wadembly
  • 489 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
SOURCE: How do I replace the main drive belt on a
No you don't, it's easy. Pull all the cotter pins out of the deck mounting brackets until the deck is laying on the ground and slide the deck out to the side. Make sure the parking brake is engaged so you have enough slack for the belt and start in back and work your way forward. You should see a little picture there somewhere on the mower of how to thread the belts through the tension pulleys. Then, put the deck back on.
Posted on Apr 24, 2010
  • 5 Answers
SOURCE: My Craftsman Lawn Tractor 18 HP Briggs and
I had the same problem and talked to 3 different techs. The only solution they would come up with is to replace the carb. I didnt believe this was the problem. If you have a fuel solenoid on the bottom of the float bowl remove it and just put in a float bowl plug that threads in. I just taped up the solenoid connector. It runs better than it ever did. I believe the solenoid gets hot and starts shutting off the fuel. I used a plug from a spare set of 1977 yamaha motorcycle carbs I had sitting around.Go figure. Hope this works
Posted on Aug 01, 2010
  • 4961 Answers
SOURCE: craftsman lawn tractor cuts off when you engage the blades
You might want to post this in the lawn mower section.
Posted on Aug 19, 2012
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a LT1000 starts fine and then stalls after a short run, I have clean fresh gas, new fuel filter, oil change, battery, and spark plugs
There is a kill switch under the seat that makes sure you stay in the seat if the mower is running...my bet is that the switch is malfunctioning and the vibration of the motor is causing it to short out...get a new switch, they can't be that much...
heatman101
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman LT1000 Tractor. It has a
if you have a model # 917.272672, you can download a free user manual at
http://www.craftsmanlawn.com/Tractors-Riding-Lawnmowers/917.272673/
Oct 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
