Question about LG WM3470HWA Front Load Washer WM3470HWA
Won't start for wm3470hwa - LG WM3470HWA Front Load Washer WM3470HWA
Why won't the our LG washer start unless it is unplugged an replugged in?
it appears that maybe the diagnostic computer isnt working as it should in the washer you can contact LG by phone to have them service the washer
Oct 13, 2016 | LG WM3470HWA Front Load Washer WM3470HWA
Won t start will not turn over no crank do have lights and battery
then I can only suspect the starter has failed .
Oct 24, 2015 | Cars & Trucks
LG washing machine shuts off randomly, why?
only suggestion, next time it happens, unplug like you've done and then hold in power button for 15 seconds to see if that resets it.
Aug 30, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
Inconsistent leaking coming the back of the washer.
The inlet water valve for the cold water has three connections to it. There are a total of 5 hoses that put water in the machine. These are on the cold water side. Check them for leaks, cracks and tight connections.
Jul 24, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
How do I fixe lg washer code IE
The IE error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 08, 2014 | LG WM3470HWA 4.0 cu.ft. Ultra Large...
LG Washer gushing water out of the lint trap in bottom left corner
Get a flashlight and check the fittings. Yes there is a gasket.
Feb 15, 2014 | LG WM3470HWA Front Load Washer WM3470HWA
LG WM3470HWA Front Load Washer WM3470HWA Logo
47 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
