Question about John Deere 22HP Hydrostatic 42" Riding Mower
Scotts S1642 won't start after safety switch failure
How do I bypass the safety switches on a scott 1742 built by john deer
Bypassing the safety switches are not recommended. If you do not know how to replace a safety switch you would probably do more damage to the unit or yourself and for that reason I will not tell you how to bypass the switches. Please replace the safety switches.
Apr 25, 2017 | Garden
Under seat shutoff, which way is off? I've tried all the way both ways, won't start. Plenty of fuel.
Scott the button for seat safety switch has to be pushed in for start .
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test lawn mower electrical safety switches
How to Test Lawn Mower Safety Switches
Apr 24, 2016 | Garden
2000 ford windstar won't start after changing safety neutral switch?
You need to adjust the Switch, it thinks you are in Gear
Apr 09, 2013 | 2000 Ford Windstar
Why does my scott lawn tractor s1642 stop running after about 5 minutes?
Check your fuel cap. If it has a vent that isn't working, the fuel tank will build up pressure because no air can get into the tank and will then prevent fuel from getting out to the engine. You may need to replace the fuel cap. If so, you can get one at PartsBuggy.com.
Dec 01, 2012 | Garden
Install drive belt for scotts s1642 rider lawn mower
check size of belt make sure its correct make sure routing is correct andput belt on tension pully last you may have to pull on it to get it around it
Aug 30, 2012 | Garden
I need to see a belt routing diagram for a Scotts Mower
This is for a Scotts 1642. Picture yourself sitting on the mower looking down at the deck. Starting at the tractor pulley, the belt runs from the right side of this pulley to the left side of the tension arm pulley, around this pulley to the left side of the right hand side mower blade pulley, around this pulley, across the deck to the smaller left hand side idler pulley, then up to the left hand side mower blade pulley, around this pulley to the second (larger) idler pulley, around this pulley and back to the left side of the tractor pulley. If you make a small sketch of the deck pulley arrangement it will be easier. Keep in mind some of the pulleys are for the "V" side of the belt and some (The tension arm pulley & larger idler pulley) are for the flat side of the belt. Be sure the belt is not twisted and lays in a continuous circle with the "V" side of the belt on the inside before you start.
from http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=135
Please vote !!
May 12, 2010 | Garden
Scotts 1642 riding mower take foot off brake engine shuts off
Sounds like the safety switch in the seat is bad or disconnected. Look under seat to see if anything is unplugged.
Nov 05, 2009 | Briggs & Stratton Garden
I need a digram of replaceing a drive belt on s1642 scott lawn tractor.
You can download the owners mqnuqal here:
http://dl.owneriq.net/2/2141e15a-36a6-9594-0166-6f10fba50f44.pdf
It has full instructions as well as diagrams
Sep 23, 2009 | Garden
Does scott mower #S1642 have a magnito? if so how do I access it?
no there is no magnito. what is the problem you are having, i can help you.
Jun 25, 2009 | Garden
John Deere 22HP Hydrostatic 42" Riding Mower Logo
42 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
