Question about Canon PIXMA MP150 All-In-One InkJet Printer
Ip1880 reset didn't works
I've tried the tips but still not works. My Canon ip1880 still blinking after 1 restart the power. I've also changed the cartridge with the new one but the same problem still occur. Please help ...
  • 11 Answers
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Posted on Sep 08, 2009
My general tool ip1880 not work in my computer
Posted on Aug 10, 2009
    Champion:
  • 214 Answers
Try pull power cord out wait 2 minutes plug in try again
Posted on Apr 24, 2009
How to solve 5100 error of canon pixma ip1880 series printer
Follow this procedure:
1. Enter Service Mode: Hold Power button and plug a power cord, then push Resume button twice and release all buttons.
2. Free Download from Internet: GeneralTools for Canon Pixma IP1880
3. Starting GeneralTools
4. CHANGE USB PORT change into PORT of your printer
5. click lock release
6. click ip1800
7. click device id
8. clear waste ink counter by clicking MAIN & PLATEN
9. Check EEPROM Box
10. Click EEPROM Dump
Power off printer and all done. Work again!
Jan 11, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Error occurred 6000
It's an ink level indication.
If you are using re-filled ink cartridges, try this.
To solve the ink level error in canon Pixma iP1800/Canon Pixma iP1880. This problem usually appear after refilled the cartridge on the canon printer and ink level indicator showing the ink cartridge is empty although you have filled a cc Ink into the cartridge. And if the problem occur you cannot using your printer to print. The solution you must reset ink level on the printer if you want your computer work again.
If you have a problem like that you ca follow this tutorial to solve your printer problem, here how:
Turn of the printer and Disconnect the power cable to the printer.
Press power button on the printer. While pressing the button connect the power cable to the power source (the power indicator will light in green)
While still holding power button press resume button twice - orange blink and return to green.
Release the power button, then the PC will recognize new cartridge installed (If the power indicator on the printer steady in green you continue to Steps 5)
Run the IPtools software, please await after this software detect your printer correctly or you can set the printer model on "Change Model" section.
Click "reset black and reset color" button to reset the ink level and Click "reset main and reset platen" to reset waste ink counter. After clicked the button you will see ink level of the cartridge on in the IPTol info has 100% and WP and WM has set to 0. Click Exit on IPTool
Turn off the printer and turn on again.
On the reset procedure above usually the problem found on steps 1-4 to make the printer steady light in green. On my experiment if steps 1-4 does not work on your printer, you can use manual reset method for canon iP1700 before continue to steps 5.
Good luck
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My canon ip1880 printer orange light flashing 7 times even after I have installed both my cartridges correctly.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Oct 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Problem on my Canon ip1880
Unplug the printer from power for a few minutes. If this doesn't reset it, then try the following:
PLUG the printer into power.
1. Press Resume button ( hold for 1 – 2 minutes )
2. Open the cover
3. Release the catridge and then put them in again
4. Close The Cover…
5. Turn Off, then Turn On
Jan 21, 2009 | Canon Office Equipment & Supplies
CANON IP 1880
i need install canon ip1880.. how?
Mar 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
IP1880 Canon PIXMA showing Ink absorber full
Pixma ip 1880 is full(solution)
1. first unplug power cable and usb cable
2. hold power for 1-2 minutes
3. turn on power
4. your printer should back to normal printing
Mar 07, 2008 | Canon I990 InkJet Photo Printer
Resetting Canon inkjet printer
Perhaps change the cartridges?  You might also try to clean them.  If this doesn't work, you're probably looking at a new printhead.
Oct 27, 2007 | Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
862 people viewed this question
old marine
old marine
