Question about Velocity Micro Cruz Reader R103
Forgot device pattern - Velocity Micro Cruz Reader R103
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Nov 29, 2015 | Tablets & eReaders
How do I open Tablet if I forgot pin #?
Recover Android Device in case of Forgot password/pattern ...
visihow.com/Recover...Forgot.../pattern_unlock_an_Android_device
To perform a Factory Reset, take the following steps: Turn off your Android device. Press and hold the "power", "volume down", and "camera" buttons simultaneously. Release the buttons once your Android device is powered on. Scroll using your "Volume up and down" button until you find the "Factory Data Reset" option.
I just bought a ouku tablet from a yarf sale, it has a lock screen swipe pattern, and i don't know what it is, any way to help me unlock so i can set up service and use it?
Read it on a forum:
You need to recover it first the Lost Password Via Recovery email of your android device. On the locked Screen Tap the Forgot PIN or Forgot pattern. Then enter the email address that was registered on your Device then Enter also the correct password. After that, use a PC to log on to the Gmail account and check for the Email Recovery from your android device.
May 17, 2015 | Tablets & eReaders
My irulu tablet will not let me open screen without pin#. I was not given one
If it's an android device...
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Good luck.
Jul 20, 2014 | Irulu 7" Touch Screen 2gb Android 2.3...
My big lots tablet is lockedand i cant remember the pin itsa d2 7in.what can i do ?
also, see here...
Jul 04, 2014 | Tablets & eReaders
FORGOTTEN UNLOCK PATTERN
It is quite normal that after providing an unlock pattern to your tablet or mobile, you forget the pattern and attempt unlocking the device multiple times. In this process, many times your device gets permanently locked, and you no longer get any access to it. If you have forgotten your recovery email, you will not be able to unlock the device using that option as well. More.. How Do Unlock My Tablet if Forgot the Unlock Pattern or Recovery Email
Apr 17, 2014 | Tablets & eReaders
How to bypass forgotten snack pattern and login details on samsung galaxy 3
Hi if you forgot your pattern and email the only option is to reset your device to factory default.
Apr 08, 2014 | Tablets & eReaders
Pattern unlock code
it will show an option forgot pattern try pressing that button and then follow the procedures
Mar 23, 2014 | Android 7 inch Tablet
Forgot my password to get into my android table MID M729 the pattern on the top of the tablet
Normally, with Android devices, if you enter the wrong pattern five times in a row, the device will give you an option to enter your Google account information (e-mail address and password). Once you have done this, it will let you reset your security pattern.
If this doesn't work, the next best thing to try would be a firemware The firmware update process will wipe the root of the device (but leave your SD card and books intact), basically resetting it to factory settings, before you even set a security pattern.
Should this fail to work, contact Velocity Micro Support by calling +94756523353
Dec 28, 2012 | mid Archos M729B Android Tablet
I forgot my pattern what do i do
If you enter the pattern wrong 5 times, android devices will prompt you with an option to enter your Google email and password. It will then let you reset your pattern.
Jan 18, 2012 | Velocity Micro Cruz Reader R103
Velocity Micro Cruz Reader R103 Logo
14 people viewed this question
Top Velocity Tablets & eReaders Experts
 Mikey
Mikey
deton8 von Splosion
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
