Question about Pentax Optio 60 Digital Camera
How to fix memory error - Pentax Optio 60 Digital Camera
How do I fix error code c-6740 on Konica Minolta c7000pro
C6704 Description Image input time out
Image data is not input from the scanner to the MFP board (MFPB). Remedy 1 Select [Service Mode] - [State Confirmation] - [Memory/HDD Adj.] - [Memory Bus Check] - [Scanner-Memory], and conduct the memory bus function. 2 Check the connectors between scanner section and MFPB for proper connection and correct as necessary. 3 Replace MFPB. 4 Replace CCDB.
Dec 09, 2014 | Konica Minolta bizhub Office Equipment &...
Each time i put my memory car in my phone that is a blackberry 9000 i get a message saying " A media card has been inserted that contains errors. To correct the errors please use a disk error-checking...
Hello.
To do that, you need a card reader. Insert your memory card into a card reader, then:
Insert the card reader into your computer's empty USB slot.
Go to "computer" or "my computer".
Right click on the drive of your card reader and choose properties.
Click the "Tools" tab then click "Check now"
Check "Automatically fix errors" and "Scan for and attempt to recover bad sectors"
Click "start" and wait for it to finish.
That should fix the errors. If it doesn't, format your memory card.
Thanks for using Fixya!
Jun 22, 2011 | Cameras
My pc won't work correctly. I cant reboot, it just has these horizontal coding lines and then wants to do startup repair but that doesn't do anything. I then decided to try to take it back to factory...
The Memory could not be read error google_ad_client = "pub-5406364303442190";/* 336x280, created 7/6/08 */google_ad_slot = "2528346899";google_ad_width = 336;google_ad_height = 280; tweetmeme_url = "http://www.ghacks.net/2007/05/10/the-memory-could-not-be-read-error/"; tweetmeme_source = "tweetmeme"; Share I know that this may sound funny but I also received the error "The memory could not be read" during Windows startup. The funny thing is that this error and the error "the memory could not be written" are not related to each other. I found a fix that helped pretty fast. The memory could not be read is apparently a Java error which is causing the problem. You find a big explanation with various solutions at a official Java website.
I would still like to outline how I fixed this error. The Java website has several solutions to get rid of this error and you should start at solution 1 and the error will hopefully disappear after you have tried solution number 4 which is the last one in that list. My error disappeared after trying solution number 1. Here is what I did to fix "the memory could not be read".
I went to the directory C:\Program Files\Common Files\InstallShield\Engine and renamed the Engine directory to Engineold. After renaming that directory download the latest Java Runtime Environment from Sun and install it on your computer. The error disappeared after restarting my system.
You should try solution 2, then 3 and lastly 4 if the first solution did not work out to get rid of "the memory could not be read".
google_ad_client = "pub-5406364303442190";/* 300x250, created 2/27/09 */google_ad_slot = "1148508964";google_ad_width = 300;google_ad_height = 250;
Oct 21, 2010 | Computers & Internet
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
Aug 07, 2010 | Computers & Internet
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
My photocopy of canon ir3100f the give massage code error on screen i want solution
Wich code?
Here is examples:
E000 Insufficient temperature rise of the fixing unit at power-on
E001 Abnormality of the fixing unit
E002 Insufficient temperature rise of the fixing unit
E003 Low temperature of the fixing unit after standby
E004 Error of the protection circuit in the fixing unit
E006 Connection error of the fixing unit
E008 Life expectancy of the fixing roller
E010 Main motor error
E012 Drum motor error
E013 ITB waste toner full error
E014 Fixing motor error
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
E021 Developing rotary error
E026 Toner empty error
E032 The counter of the NE controller fails to operate.
E045 OHP sensor error
E067 High voltage-related error
E070 ITB HP detection error
E100 BD error
E110 Operation error of the laser scanner motor
E202 CIS unit HP detection error
E225 CIS light quantity error
E227 Power supply error in the reader unit
E243 Control panel unit error
E248 Backup memory error
E315 Abnormality of image data
E351 Main controller PCB error
E400 Feeder communication error
E490 Model error
E500 Finisher communication error
E503 *** Finisher internal communication error
E505 Finisher backup memory error
E514 *** Stack delivery error / **** End assist motor error
E519 **** Gear change motor error
E530 *** Rear alignment error / **** Front alignment error
E531 Staple error
E532 Staple unit shift error
E535 Swing error
E537 *** Front alignment error / **** Rear alignment error
E540 *** Stack tray up/down error / **** Upper tray up/down error
E542 **** Lower tray up/down error
E577 *** Paddle error
E580 Stack tray up/down error
E584 **** Shutter unit error
E590 ***** Puncher motor error
E591 ***** Puncher dust sensor error
E592 ***** Puncher side registration sensor error
E593 ***** Puncher shift motor error
E5F0 **** Saddle paper positioning error
E5F1 **** Saddle paper folder error
E5F2 **** Saddle guide error
E5F3 **** Saddle alignment error
E5F4 **** Saddle rear side staple error
E5F5 **** Saddle front side staple error
E5F6 **** Saddle paper push-on error
E5F8 **** Saddle connector error
E5F9 **** Saddle switch error
E601 Abnormality of image memory
E602 Hard disk error
E604 The image memory (SDRAM) is faulty/insufficient
E609 * Abnormal low temperature of the hard disk
E610 ** Failure in the hard disk cryptographic key
E674 FAX board communication error
E677 Abnormality of the external controller
E710 IPC initialization error
E711 IPC communication error
E712 Communication error between the ADF and the reader
E713 Communication error between the finisher and the printer
E717 Communication error with the NE controller
E719 Communication error with the coin vender/card reader
E730 PDL error
E731 UFR PCB error
E732 Reader communication error
E733 Printer communication error
E740 Abnormality of the Ethernet board
E743 DDI communication error
E744 Language file/BootROM error
E745 * Token ring board error
E746 * Option board error
E747 Main controller PCB error (Image processing ASIC or memory control/communication control
ASIC)
E748 ** Main controller PCB error
E749 ** Restart in accordance with a change of the product configuration
E803 Door close error
E804 Controller fan error
E805 Fan error
Jun 26, 2010 | Canon iRC3100 Printer
My memory card is corrupted how i can repair
Hi
Memory card corrupt errors occur when ejecting without safely removing
from system or from phone which causes some files delay write fail
Your memory card problem can be solved in many ways
Firstly
1.Insert the memory card in card reader and
in windows xp go to the drive properties of memory card by right clicking the drive and select
the tools TAB and select "Check now" as seen in check errors
and tick both " Automatically fix file system errors" and " scan and recover bad sectors "
click start and it will fix all file system errors
and all your data is safe too
2. another method is format your card. but it will erase all data
hope this will solve your problem
Feb 28, 2010 | Computers & Internet
Error 8022008B.....
If it is having trouble formatting in a PSP try taking it out and formatting it on your PC in Windows. Hope this solves your problem!
Please rate!
Cheers
Oct 04, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
DIMM Error HP P3005n
Hi, The Dimm Error your receiving does it have any numerical codes ? The firmware could possibly be defective ?
Dec 03, 2007 | HP LaserJet P3005n Printer
Pentax Optio 60 Digital Camera Logo
49 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
