Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
On a 1997 cheverolet 1500 pick up my problem is the tachometer doesn't work plus the speedometer and the shift selector light. all the fuses has being check. they said it could be the ignition on the steering columen that it leave to the trainmission. if is true is it easy to fix myself.
  • 1 more comment
  • pneriajr Apr 24, 2009
    you mean that this speed sensor make the instrument panel stop working while drivering
    second question you telling me that the speed sensor make the instrument stop working while you are driving yes or no
    I'll will have to get back with you later to make a commented.But it is a started of getting value imformation in a short notice. That I like very much knowing i can get some kind of answer this later at night. Thank You very much for your help
  • 3,037 Answers
Since you have already checked the most logical part, the fuse then move on to checking the vehicle speed sensor? If that doesn't work, let me know, you should be able to replace it yourself fairly easily. Let me know if you have any more questions.
Benjamin
Posted on Apr 24, 2009
  • Benjamin Patri
    Benjamin Patri Apr 24, 2009
    Yes it will keep the tach and the speedometer from working since they are all interconnected.
  • Benjamin Patri
    the speed sensor sends a signal of how many rpms and mph you are running so both things will go at once if it is the problem.
Wont crank cold
The white wire will only have voltage in the Off (bulb test), Run, and Start positons. It will not have voltage in the Lock or Accessory Position. When this wire's contact opens you will have no Tachometer, Speedomete, or Gear shift indicator. Also the Check Engine light will be on and Transmission will be usually stuck in 2nd gear (called limp mode). I installed an aftermarket replacement switch and it last 92 days. I am going back with the OEM replacement and now troubleshooting connections, Grounds, and Shift solenoids, tranny, Ect
Jan 11, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
1997 chevy suburban speedometer not working
Check your fuses. Probably one burnt out.
Apr 04, 2013 | 2003 Chevrolet Suburban 1500
Today I started my 1997 GMC Sierra K1500 4x4 and the little light that moves under the P R N D 3 2 1 shift indicator did not come on. Neither the speedometer nor tachometer work and the truck drives...
1997 GMC Subburban 1500 loses Tach Speedo and Trans sticks in High Gear. I changed the ignition Starter switch which I read was the problem but problem is intermittant and still exist? AMMCO told me to try changing the Neutral Saftey switch first, but didn't say why?
Oct 07, 2010 | 1997 GMC Sierra K2500
I need wiring diagram for ignition switch for 1997 chevrolet tahoe
red and red/white is 12 volts constant
pink is ignition
white is ignition 2
orange is heat/ac
brown is accessory
Aug 07, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
1995 chevy k1500
Sounds like a simple fuse problem. Try checking and replacing fuses inside the truck and under the hood as well. check them ALL, as some fuses say they control one thing, but end up controlling more than a few :)
Apr 22, 2009 | 1997 Chevrolet K1500
Gauges don't work, Fuse panel is a pain to get at
I have a '97 Chevy 1500 with an automatic trans. This morning i started it up and the speedometer and tachometer needles sit at zero. Also the gear selector fails to light up. Upon accelerating from a stop, it starts in third gear. I can manually downshift to second but not to first. It will not upshift automatically. Only manually. Also, it will not shift into overdrive when up to speed. The check gauges light comes on but only intermittently.
Additionally, the service engine light came on however I suspect that this is a separate problem as the 262 engine does not run well on this horrible new 10% ethanol fuel and it makes it throw an O2 sensor code. Does anybody have a clue here? I changed the 10amp fuse for the gauges but it hasn't fixed the issue. I didn't think it would resolve it because the rest of the instrument panel works (oil pressure, temp, voltage, fuel). Please, any advice.
Apr 13, 2009 | Chevrolet G30 Cars & Trucks
1997 yukon throwing transmission codes
check fuse o at left fuse by drivers side box for power when key is on. if no power replace ignition eletrical swicth at steering colum
Mar 28, 2009 | 1997 Chevrolet K1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
150 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
