Question about Ridgid 10"Wet Tile Saw with Laser and Stand
The ridgid r4030 won't start. I thing the start button might be the problem.
How to I remove rubber boot and change blade clamp assembly on my Ridgid R864 cordless reciprocating saw
Frank remove lever,pin and shoe, and slide/pry rubber boot off, Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ridgid R864 Cordless Reciprocating Saw Parts
How do remove the rubber boot which covers the front of the Rigid R3002...
http://www.homedepot.com/catalog/pdfimages/5e/5eda0284-2196-4e9f-80f7-73264ab9f6d3.pdf
Apr 22, 2016 | Ridgid Saws
Ridgid 18v x3 saws
The battery may have a short in it. Take it back to Home Depot for a new one. Rigid has a lifetime warranty on their cordless products.
Aug 25, 2014 | Ridgid 18v Circular Saw X3 tool Only R865n...
My 12 volt Ridgid drill just quit alltogether. I know it,s not the battery or charger as I have an identical drill and it works just fine. This drill takes the small cartridge type battery. Any...
To start, I assume you took the "good" battery from the working drill and tested the inoperative drill.
Good for doing that.
The other causes I know of in Drills that turn them into paper weights are as follows:
1 Worn Brushed: You can attempt to test this by squeezing the assumed good trigger button and
Taping the drill or lightly banging it on a bench top or something else. If it is brushes, it will often but no necessarily all the time, start to run for a moment, or just running. Since you use the drill and "use it a lot" That will be the first thing I would look for.
2 Trigger Button.
I would bring it to a tool service place or send it back to Ridgid. Try this link
http://www.ridgid.com/Tools/Technical-Services/index.htm
Hope this helps, Happy New Year
Mark
Jan 01, 2011 | Ridgid 12 Volt Cordless 3/8 In. Drill
Motor will not start on my Ridgid table saw
Check the brushes and the commutator for wear and buildup between the insulated areas of the commutator..It should be clean and not full ofcopper residue.That will make the motor click only upon triggering the starter switch
Jun 03, 2010 | Ridgid Reconditioned 10" Jobsite Portable...
Cant push in the release button to take off the blade on a Ridgid R3200 circular saw
Happens to my Milwaukee sometimes. Spin the blade around (by hand) while trying to push in the lock button. That will usually engage it. If not, the old-fashioned way of wedging the blade against the base with a piece of scrap wood always works
Nov 27, 2009 | Ridgid Saws
18 volt ridgid drill locks up
be sure the switch is in either reverse or forward. if it sits in the middle position, it wont run
Apr 09, 2009 | Drills
Ridgid air compressor OF45150A twin stack
sounds to me like u do not have it on a big enough circuit, look on the name plate for FLA, this is the amps it pulls to start up, and size ur circuit for that amount.
Dec 28, 2008 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
Need owners manual for a uniden scanner model#r4030
Here is the web site from Uniden to download owners manuals from. Are you sure of the model number?
http://www.uniden.com/index/manuals_results.cfm?cat=3
Dec 22, 2008 | Audio Players & Recorders
Ridgid 10"Wet Tile Saw with Laser and Stand Logo
80 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
