Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
How do we adjust our tv
By Macka111 on Sep 25, 2007
We are trying to tune in a tv that worked perfectly at its last location. We have plugged it into the coaxial cable here and now we have a picture but it is snowy and jumping. How can we rectify this? Our "old" tv worked perfectly before the picture tube gave up.
Would you please be able to assist with this problem?
The instruction manual seems to have been mislaid for our "new" tv.
HELP PLEASE!
Best Solution
posted on Sep 25, 2007
Helpful)
dodgecharger
Rank: Wiz
Rating: 83%, 328 votes
You didn't mention anything about a cable box, VCR, etc. which might be connected. A snowy pic. means simply, inadequate signal is reaching the tuner, or the TV tuner itself is bad. If the first is so... check your cabling. If you have a VCR or DVD player hooked in between the cable box or outside antenna (whichever is the case), VCR (RF or ant.) out should go to the TV, VCR antenna (RF or ant.) input to the cable box.
Also check the cable wire itself. If you look at the end of the cable, you should see a relatively thin center wire. This center conductor is what carries the signal. If it is missing, bent over, or too short to make contact with whatever it is connected to, you will have a very snowy pic.
If you have a spare TV, connect it in place of your "new" TV, to narrow down the problem.
Lastly, if all is well with hookup, cabling, etc. the TV might have a problem. Sometimes the tuner has a component defect, or the coaxial connector can be broken.
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
My WS-65819 won't power on. It used to power on for a very short time before shutting off before,... (More)
Answer
no picture just sound big screen panasonic tv
Answer
i need help my apex tv has child lock on and i dont know how to turn it off i have original remote... (More)
Answer
tv does not turn on. it worked perfectlty until one day when it just wouldn't turn on anymore
Answer
my toshiba hd flat screen has very little volume when turned up to 100. What is wrong? Its not a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
