I have underfloor heating and the timeguard control stops working. It indicates that it is operating, but the underfloor heating does not warm up and the temperature being recorded does not increase and floor does not warm up. It worked last winter and during the summer I reduced the temperatures and on increasing them the floor refuses to heat up. This is the third control in 6 years and i have just ordered the forth!
hotuna
  • 288 Answers
SOURCE: Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Posted on Dec 04, 2007
SOURCE: JENN-AIR MODEL D156B Electric oven
code f 0 means what?
Posted on Aug 25, 2008
aborcass
  • 2651 Answers
SOURCE: Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Posted on Nov 04, 2008
  • 63 Answers
SOURCE: My Kenmore cooktop will not heat properly, all 4
hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
Posted on Mar 11, 2009
emissionwiz
  • 79123 Answers
SOURCE: 1999 Lincoln Navigator Heating Problem
if the heater core is getting hot then the problem is the air temp control blend door actuator, a common problem.
Posted on Mar 13, 2009
My radiant floor heating suddenly stopped working. Wall thermostat is functioning normally. GFCI test is working fine. What can I check next?
Monica, There might be a break in the wire mat, you or a electrician will have to check with a digi multi meter.
Links below show how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test underfloor heating with multi meter
How do test the resistance of my electric underfloor heating system
http://www.suntouch.com/support/troubleshooting
Testing underfloor heating
Mar 02, 2016 | Heating & Cooling
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
Home comfort protection plan
Direct Energy knows that maintaining your Texas home is essential to your family's well-being. You can't afford to put off protection until disaster strikes, so we've created protection for your home's electrical, plumbing, and heating and air conditioning systems.
Our home protection plans deliver security by combining preventive and repair services for your home's most fundamental systems, including:
Electrical wiring
Plumbing lines
Priority scheduling with us for all appointments
Surge protection
Heating and cooling systems
Our home protection plans remove the anxiety of unanticipated costs, while our certified technicians are ready to assist you with respectful, professional service and high-quality equipment. Because we view the money you spend on home service improvement as an investment in your home and your comfort, we're committed to helping you make it worthwhile. You can choose from our plans for Heating and Cooling systems, Electrical wiring, and Plumbing lines. Direct Energy's Repair & Maintenance Essentials Plan provides annual features to catch small service issues before they become critical, $500 insurance for every repair job*, emergency customer support any time you need it, service visits with no charges and no deductibles, and so much more.
if you want protect your roof leaks so you can apply EPDM Coatings :
Watch Corporate Video
Jan 20, 2014 | Audio Players & Recorders
Underfloor heating wont stop running
Look for a stuck relay that controls the pump
Dec 30, 2013 | Hunter Mechanical Heat & Cool Thermostat...
Siemens underfloor heating keeps flashing 0.5degrees & the floor is HOT! What is wrong?
There is a good possibility that the controller is not set up properly.
The instructions are on the web.
Jun 02, 2012 | Computers & Internet
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Back up electric heater required.
A bit late for you probably Steve, but other browsers might be interested...
Micathermics are faster to warm up the room than other resistive heaters, but otherwise they're no more efficient - so it depends whether you feel that the fast warm up is worth the extra money that the micathermic would cost.
If your ceiling is well insulated (including over the wall plates at the top of the internal walls) then the large windows are very likely the reason that your underfloor heating can't get the heat high enough. Have you considered double glazing? 3M have a very cheap, disposable window insulation kit that you could put on for a cold season to see if it's worth putting in some more permanent double glazing (and in fact that kit will probably last 2 or 3 cold seasons if you just leave it up).
The heater power (kW) required to get that extra 2 degC depends on how well the room is insulated. Your best bet would be to find out how much kW your underfloor heating is putting out and how much degC it is warming up the room, then keep the same proportions to work out how much extra kW you need.
Jan 13, 2009 | Soleus HGW-203 Micathermic Infra-Red...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
