Hp t610 problem
System not booting
    Top Expert:
  • 12,223 Answers
Restart the computer HOLD the keys CTRL +F8 and go section troubleshooting and fix it.
God bless you
Posted on Oct 14, 2013
Installing a new blank hard drive in a DesignJet
The hard drive is the formatter in the T610.
HP has a special operating system software loaded on the hard drive, so you can't just format a blank one and install it.
The whole formatter assembly will need to be replaced.
Mar 15, 2014 | HP Designjet T610 InkJet Printer
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Tip
How to remove Multiboot Option in Windows
If under various circumstances you had to install a second Windows OS on the same system, you should have already met the dual boot option. It will pop up before booting the system permitting the user to select which OS will boot.
Boot.ini, the house of the dual boot option Boot.ini is a system file found in the system root. Because it has a major importance for the booting process.so we have to edit this boot.ini file to remove multiboot popups.
How to edit Boot.ini
1.Go to Start Click on Run
2.Type msconfig.
Once the system configuration window pops up, you will notice that Boot.ini has its own tab. Select that tab and where you see "timeout," set it to a lower or higher value. Remove/Add Operating Systems in the dual boot menuThis is the main issue.
Step 1:Right click on My Computer icon and select Properties.
Step 2:From the properties window go to Advanced > Startup and Recovery > Settings.
Here, you can both edit the timeout value and modify the Boot.ini file by clicking Edit. If you remove the second operating system from Boot.ini, the dual boot option won't appear before booting.
For more details information visit How to Remove Multiboot Option in Windows XP
on Jan 08, 2010 | Computers & Internet
Installing a new blank hard drive in a DesignJet T1100,T610
The T610 hard drive is the formatter and has a special operating system software installed on if from HP. You can't format a hard drive and install it...so the whole formatter assembly needs to be replaced when the hard drive goes bad...
I have hp t610 plotter and it incurred paper jam
Check the carriage belt for wear. Is there an error code?
Aug 19, 2013 | HP Designjet T610 InkJet Printer
Hp desinjet t610 error code 02.01.10
Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
If error comes back, call a tech. There is a problem with the Carriage Board or Trailing Cables
Aug 14, 2013 | HP Designjet T610 InkJet Printer
Trying to connect a hp designjet t610 to a network using a usb
You cant from a network on a USB connection. USB connections are for "local" printers. "add" the Designjet T610 printer to your other PC under "printers and devices" tab. Good luck !
Feb 19, 2013 | HP Designjet T610 InkJet Printer
My hp design jet t610 is making a loud sound sometimes when starting. the sound seems to come from behind the ink cartridges. what could it be ? (sorry i am not used to speak english)
What kind of sound? Kind of high pitched? It's probably just the motor checking the printhead assembly. It typically moves around a bit on power up. It's part of the boot up diagnostic check.
Jan 18, 2013 | HP Designjet T610 InkJet Printer
Dual Boot
You may have overwritten your boot.ini file.
  • Click Start, click Control Panel, and then double-click System.
  • On the Advanced tab, under Startup and Recovery, click Settings.
  • Under System startup, in the Default operating system list, click the operating system that you want to start when you turn on or restart your computer.
  • Select the Display list of operating systems for check box, and then type the number of seconds for which you want the list displayed before the default operating system starts automatically.
    To manually edit the boot options file, click Edit. Microsoft strongly recommends that you do not modify the boot options file (Boot.ini), because doing so may render your computer unusable.
If both OS's are the same, you should be able to copy and paste the line for XP and simply change the drive letter to the location of the second OS.
Jul 10, 2012 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
