Question about GE GSS25JEM Side by Side Refrigerator
Fresh food is freezing - GE GSS25JEM Side by Side Refrigerator
    New Friend:
  • 3 Answers
Turn down refridgerator temp turn up or lower freezer
Posted on Oct 14, 2013
4 Suggested Answers
  • 3422 Answers
SOURCE: freezing fresh food
HI,
The problem is with the damper door.Check that it is not cracked.If it is cracked then you will have to replace it with a new one.
Goodluck..
Posted on May 17, 2008
  • 110 Answers
SOURCE: GE side by side not very cold on fresh food side
there is one of two thing that could be going wrong here ; you may have a bad evap fan mtr and control board or yourr damper is not opening properly. i would say you have the later of the two due to the fact the rf is still making ice. one thing that causes this issue is too much weight in the door causing the door to lean and not trigger in door light switch or the switch itself is damaged. the door hinge and camm assembly can be adjusted from the bottow using a standard socket set
Posted on Jun 13, 2008
jmgldsmth
  • 2005 Answers
SOURCE: refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
Posted on May 04, 2009
Whirlpool ed25rf refrigerator side freezing on bottom
your evaporator motor may be going bad also check to see if your condensing unit and fan motor are clean this can cause similar problems.
Dec 11, 2013 | Whirlpool 25.2 cu. ft. Side-by-Side...
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
What are the advantages of freeze dried fish food over fresh food?
Some people prefer freeze dried fish food over fresh as it's easier to keep and a bit less revolting to handle. The freeze dried food kills parasites and preserves natural flavors and nutrients for a long period of time. But some fish prefer their food to be fresh, so it really depends on your fish.
Aug 26, 2012 | Archos Fish
Is there a difference between freeze-dried and dehydrated food?
Yes there is, in freeze-drying process they use a cold temperature and in dehydrated food they use warm temperature. In the freeze-frying process the fresh foods are frozen first then the moisture removed in a vacuum chamber and since the food remains frozen during the process, the food's cell structure don't change.
Aug 09, 2012 | Camping, Backpacking & Hiking
Our refrigerator is freezing our vegetables. it is turned all the way down.what is the problem?
Is food freezing in the rest of the fresh food side as well, or just the food in the lower half, like in the crispers. if its freezing everywhere in the fresh food section, you have a bad cold control most likely, without knowing the type or brand, i cant be 100%. If its a GE, you could have a different issue, but most any other brand will be a bad cold control.
If the food is only freezing in the lower half, then your evaporator fan motor is likely the problem, located in the freezer
Mar 19, 2010 | Refrigerators
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator freezes fresh food section and always runs
May 02, 2009 | GE Refrigerators
Fresh food side freezing
the air damper is stuck open or tempature control is bad. look thru the vents(use a mirror) on the left rear(top side) of the fresh food compartment (right hand door) to see if the air damper is open/closed. i am sure it will be open since your freezing food in the ref section. if it is open ,watching with your mirror turn ref (fresh food) control off. the air dmper should close, if not damper could be stuck(ice build up,piece of foam,ect) if you can determine damper door is free, then best thing to do is replace controlassy.(120.00 or so) good luck
Nov 06, 2008 | Frigidaire FRS3R5EMB Side by Side...
Freezing fresh food
HI,
Goodluck..
May 17, 2008 | GE GTS20ICNCC / GTS20ICNWW Top Freezer...
GE GSS25JEM Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
