Question about Power Acoustik CLASS D SL-5500D Car Audio Amplifier
I got 4 ''15 inch kickers 2 5500watt power acoustik mono amps my problem is 2 kickers on the right side hittin hard but the 2 on the left not.i thought the amp on the left was bad so i took the rca of the right amp&put it on the left amp&the left side was hittin hard now. i no 1 thing i have the rca's split both amps work i no its like 1 side of the rca is workin excellent&the other side workin somewhat i guess. so i unplugged the rca on the right amp&let the left side play that side not hittin hard at all. is it that i have 1 rca jack on 2 amps please help if you can.
  • 55 Answers
Sounds like you have a strong signal from one set of rca wires. I would take the strong side and split that. it depends on where you getting sound signal for rca from. try adjust radio and amps. sometimes tuning is a pain. make sure grounds are good for both sides, bring somewhere someone can actually see what is going on.
Posted on Apr 24, 2009
  • 655 Answers
Hello herb31,
It sounds like there is a difference in the signal levels on the inputs to the amps. You did not specify what the RCA's are connected to on the head unit side. If they are connected to a stereo pair of preamp outputs, you may be able to solve the problem by using only the channel with the higher signal and use an RCA "Y" adapter to split it to both amps. If they are connected to a dedicated subwoofer output on the head unit, make sure that the head unit is set for "subwoofer". Some less expensive head units, I know JVC in particular, has only 1 set of line outputs and requires you to go into their "PSM" (Preferred Setting Mode) to set the line output mode and if you select "subwoofer", then allows you to select the low pass frequency.
If you are converting speaker-level outputs through a "line out converter", check both the input and output levels.
Also, if you are splitting an output from the head unit, you still need to connect 2 RCA's to the amp inputs. The signal will be properly split if you use a 1-female to 2-male "Y" adapter. To feed the same signal to both amps, you would need 3 "Y" adapters. Feed the output signal to the female end of the first "Y", and plug the male ends into the other 2 "Y" adapters. Then, the 4 plugs you have left on the ends go into your amp inputs.
Hope this helps.
How do you wire 2 15 inch kicker cvx dvc 4 ohm subs to a 1700.1D hifonixs mono amp so i can get the most power
Wire both hot wires together and both ground wires together then wire them to the amp with the hot on one speaker output and the ground on the other speaker ground. This puts them in the bridged position. Pulls the maximum watts out the amp and unbelievable sound.
Feb 20, 2015 | Kicker Car Audio & Video
Need a wiring diagram to hook up two 10 inch subs and 15 inch sub a kicker 250.1 amp
Series or parallel? Single, dual voice coil? I'm not sure you have the right size amp for all 3 speakers. And I wouldn't wire the 10's together with the 15. The larger sub is going to have a larger power demand. You could wire the 2-10's together on this amp, and get another mono amp for the 15.
Oct 02, 2014 | Car Audio & Video
Is it safe 2 install these subs 2 a 2000 watt power acustic amp and if so how do I wire them for a 1 ohm stable load
It looks like you have the Power Acoustik OVN1-2000D Mono Block 2000 Watt amp.
Monoblocks all feed speakers normally and cannot be bridged. So hookup your speakers
as normally with + on the amp to + on the speaker and same with the -.
Now for the speakers. I dont know too many Kicker speakers that are 1 ohm but the
monoblock wont care. It will feed the 8,4,2 or 1 ohm speakers the same power. You just may
get less response from the higher ohm speakers-less Bump Bump. You could wire your speakers
in series to get a lower ohm load (2-4ohm speakers in series gives the amp a 2 ohm load) and get
better response. Here is a site that answers many electrical and speaker questions.
See # 57 on the right hand pane. Tells you exactly what will do best. Good luck.
Electronics Answers Made Easy
Apr 27, 2011 | Kicker Car Audio & Video
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have the 2442 fx behringer ''XENYX'' mixing console, and while trying to operate channels 13/14 and 15/16 (these are both stereo channels with mono capabilities, and do not have XLR inputs) I only get...
Check you assign buttons and bottom (three black square buttons) and play with them. It sounds as if you are not sending to that side. You should use mono cables into left and right. I set pan on left all the way left and right, all the way right. Hope this helps.
Jul 06, 2009 | Music
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
Power Acoustik PTID-8960
You can Actually get a Single to Double RCA Splitter for this. I think that Wal-Mart Used to Carry them. If not, Any Stereo Install shop has these and will sell them to you. You Might Try Best Buy also. Their Car Audio Install Guys may have one to sell to you.
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
Power Acoustik CLASS D SL-5500D Car Audio Amplifier Logo
218 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
