Question about Husqvarna Garden
My model RZ5426 wont start. I checked all switches, fuses are good 20A & 7.5A. Blade not engaged. I disconnected the starter cable at the solenoid and tested that terminal with a test light. When I turn the switch that terminal show not power. The other terminal on the solenoid is hot because that is connected from the positive battery terminal. Not sure what to do next to try and get it to crank. Any suggestions
  • 625 Answers
SOURCE: STARTER WILL NOT CRANK OR CLICK
first is the truck automatic? or manual transmission, this information is important to know because the neutral switch on the automatic plays an important place on the starter circuit, and on the manual trans, the clutch switch does the same, also make sure you have not aftermarket alarm on the truck because that will interfer with starter cicuit, and to test the ign switch just test every wire close to the swtch and you suposed to get power at least on one cable while trying to crank it,
Posted on Jun 17, 2008
bbtoast
  • 319 Answers
SOURCE: 1981 Corvette will not start
The neutral safety switch is located in the shifter housing.
Here is a link to a good article on this topic, that would beat an explanation from me.
Brian
Yes, it sounds like the NSS is the culprit.
Posted on Aug 04, 2008
  • 43 Answers
SOURCE: car won't crank
although your ignition switch would have power go to the accessories, it still could not turn over. it happened to me, after a week of trouble shooting i went and found a starter button and spliced it into the ignition wires to see if that was the problem, lo and behold i turned the key on to run and pressed the button. and she fired right up.. if you know anyone with mechanical skill. its pretty simple to set up. took me 10 min to do.
good luck
Posted on Nov 16, 2008
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
a96xz003
  • 23 Answers
SOURCE: 1989 Honda Accord won't crank - starter good - what next?
check powers out of the ignition switch big in big out usually first place to start
Posted on Jun 20, 2009
2003 ford focus zx3 2.3l auto.. starter needed replaced due to test of solenoid wasnt working bench tested.. installed new starter..wired it up same.. now turn key amd i can hear starter motpr spin bit...
Yes, it is possible for the starter to spin without the solenoid engaging. The solenoid pushes the spring loaded gear forward to engage the flywheel.
You need to crawl back under your vehicle and ensure you've properly attached all wires. It should look similar to this:
starter-d053pipvg1eiz5wan5nws05s-1-0.jpg If these wires are properly attached, then check for power and/or damage to wires. The secondary will only energize when the ignition switch is engaged, so you'll need help (test when not attached to starter).
Jan 23, 2018 | Ford Cars & Trucks
LX176 John Deere lawn tractor doesn’t get power to the starter, I have replaced the ignition switch and still nothing. Can anyone help?
Oftentimes there are switches at the blade engagement lever and under the seat...for safety reasons. I can't start my mower if the blade drive is engaged and /or I'm not in the seat. That's a clue to check , however I'd check the starter solenoid first.
Oct 17, 2017 | John Deere Garden
My 92 600 katana wont start. It wont even turn over, when i press the start nothing happens. the battery is good i charged it up and all the lights work but it still wont turn over.
If the clutch switch, the neutral safety switch, and the side stand switch are all working correctly, then test the starting system. When you push the starter button you should hear a click , so you know the button is working.Follow the positive battery cable to the starter solenoid. Disconnect the two wires that activate the solenoid, test the two wires from the harness make sure the needle on your voltage meter jumps when you push the starter button, this means the button is good. Take a wire and jump the two posts on the solenoid or touch the two cables together. If your starter works, then you need a new solenoid. If you hold the starter button and tap on the starter with a plastic hammer and the starter works you need new starter brushes. Anything else wrong with the starter and you need to replace the starter assembly , the manufacturer does not make replacement parts for the starter.
Jul 28, 2011 | 1992 Suzuki GSX 600 F (Katana)
96 Olds Aurora wont start nothing happens when i turn the key,battery is good.
CHECK THE INSTRUMENT CLUSTER FOR POWER TO GAUGES TO SEE IF THEY WORK WHILE IGNITION IS IN THE ON POSITION.IF NO CHECK THE 40 AMP IGNITION FUSE.IF FUSE GOOD IGNITION SWITCH IS BAD OR HAS A LOOSE OR BROKEN WIRE.IF FUSE GOOD ALL GAUGES IS WORKING.I BE LOOKING AT STARTER AND STARTER SOLENOID.REMOVE THEM HAVE AUTO ZONE TEST STARTER.OR YOU CAN GET A REMOTE STARTER SWITCH AND SET OF BATTERY CABLES.HOOK BATTERY CABLES TO A BATTERY.WITH STARTER OUT OF CAR TAKE BATTERY CABLES HOOK NEGATIVE BATTERY TO STARTER BODY FOR GOOD GROUND.TAKE POSITIVE BATTERY CABLE HOOK TO STARTER POSITIVE TERMINAL WHERE POSITIVE BATTERY CABLE GOES.THEN HOOK THE REMOTE SWITCH RED WIRE TO STARTER POSITIVE TERMINAL AND THE OTHER REMOTE SWITCH WIRE TO THE S OR SWITCH TERMINAL ON STARTER SOLENOID.PRESS THE REMOTE SWITCH IS STARTER RUNS GOOD WITH NO FUNNY NOISES ITS GOOD IF STARTER DONT RUN THE STARTER SOLENOID OR STARTER IS BAD. THE PROBLEMS IN YOUR CAR COULD BE A BAD KEY TRY ANOTHER KEY YOUR CAR HAS THE THEFT DETERRENT MODULE SYSTEM BEST TO HAVE CAR SCAN TO CHECK THE THEFT SECURITY MODULE AND THE TRANSMISSION NEUTRAL SAFETY SWITCH IF ITS BAD STARTER WONT WORK.ALSO CHECK THE THEFT DETERRENT MODULE RELAY. BEFORE REMOVING BATTERY CABLES TURN OFF RADIO SO YOU WONT LOSE YOUR RADIO PLAYING CODE.
May 20, 2010 | 1998 Oldsmobile Aurora
All the mower will do is click when trying to start. Battery is fine I took out and had it checked
starter solenoid,switch ,starter,fuse, or one of the safety switches--seat,blade engage satety, need to check the wiring or connections but start with the inline fuse than solenoid these two are the most common problem after a dead battery
Feb 02, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2160 when turning ignition switch in second position, starter motor starts spinning. blows 20A fuse
You have either a short in the solenoid trigger circuit, and a faulty solenoid. To check, disconnect the small trigger wire on the solenoid. Turn key to 'START'. If fuse blows, there is a fault in the wiring. If not, the solenoid is faulty.
Oct 31, 2009 | Garden
How to trouble shoot starting system 98 ford crown victoria
Also check to see if there is power in the start wire form the ignition switch, the wire is a white wire with pink stripe, most likely not a common problem, but still something that could go wrong. this wire will feed the starter relay under the hood...
Sep 21, 2009 | 1997 Ford Crown Victoria
Older Craftsman 43" 17 HP Briggs
Check to make sure battery is above 12.3 volts, secondly bypass the solenoid to the starter by using jumper cables and see if the starter works, if so, you sureley have a safety switch problem, I beleive you have five on this model,
good luck
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Grand Am wont start or roll over
Is the security light blinking? If not, check the starter.
Mar 12, 2009 | 2003 Pontiac Grand Am
Garden Logo
202 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
