Question about Thermador PC366BS Stainless Steel Gas Cooktop
Igniter issue - some do not turn on other do not turn off
The igniters on the two right burners keep clicking even after the burner lights. The igniters on the left side do not come on. However if you turn on the right side and after it lights, then turn on the left side, all burners turn on and igniters will stop clicking.
    Problem Solver:
  • 7 Answers
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Posted on Sep 28, 2007
SOURCE:
Gas burner won't light unless gas is turned down to the low position.
I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
Feb 20, 2014 | Jenn-Air Cooktops
Ingiter will either fail to start burner or won't quit clicking on the 1% of the times it does start up the burner
Hi look for adjustments to the lighter and also there should be a sensor tat sees the fire , this sesor allows the main gas to turn on, but only if it feels the heat , kind of like a thermocouple , if you think about about any type problem like this: what is it not doing ? then think what could cause this >/? if you go about any repair this way there is nothing you can't fix unless you need a part !
Dec 05, 2011 | Jenn-Air JGC8430 Gas Cooktop
The igniter on the left front burner of the
YOU HAVE a shorted ign sw. some of these only came in a wire harnes of 4 . and if they don't change all four when in there .. mm hope this helped .. feed back pls ..
Jul 20, 2010 | Amana AKS3040 Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Igniter misfire
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 25, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
Aug 14, 2007 | Dacor Preference SGM365SS Gas Cooktop
Thermador PC366BS Stainless Steel Gas Cooktop Logo
447 people viewed this question
Top Thermador Cooktops Experts
Spencer Field
Spencer Field
Level 1 Expert
Eric Gundersen
Level 1 Expert
Archie Ferrarini
Archie Ferrarini
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
