Question about DeLonghi ECAM 23.450 S Espresso Machine & Coffee Maker
Our machine does flush water anymore, neither will we get coffee, we get the message to adjust grinder.
4 Suggested Answers
  • 92 Answers
SOURCE: Delonghi Magnifica 3500.. error message says
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Posted on Jan 12, 2011
SOURCE: no water is pumping thru the water spout or the
I got this machine and there was grinding noise but no water coming from the spout or coffee from the dispenser.
Took the back cover off. The big lump in the middle is the water pump. One of the wire connections was hanging off mine. Pushed the connector back on and everything worked fine.
Great coffee, rubbish construction!
Posted on Feb 10, 2011
  • 11800 Answers
SOURCE: WATER WAS POURED IN THE
The grinder is completely clogged with crushed coffee beans that have been clumped together by the humidity - the teeth on the rollers that were supposed to grab and smash the beans are filled and the new beans just jump around.
All you can do is to dry the mechanism with a hair dryer and then clean the teeth with a long needle. Ideally the entire mechanism will have to be removed from the unit and dried and cleaned thoroughly.
Posted on May 24, 2011
DeLonghi Rialto EAM-4500. When I turn it on, it makes loud noises and give me the following message:Ground too fine adjust grinder and insert water spout
Step: 1 Switch off your coffee maker. Remove the first brewer unit. Wash it thoroughly under running water.
Step 2: clean the coffee grinder using vaccum cleaner.
Step 3: switch on the Machine !!! Make Coffee
(Note: if you hear loud noises during coffee preparation then please use food graded grease to fix it)
Mar 19, 2017 | DeLonghi Coffee Makers & Espresso Machines
Empty circuit fill circuit insert water spout press ok
when inserted the water spout if the water is delivered,that means you have an issue with the flow meter and you have to tack it to maintain,
how ever if the message (fill circuit ) turned off after the posses of filling the circuit and when you are trying to brow coffee the message shows, that means the grinder is too fine adjust it and try ones more
Apr 12, 2015 | DeLonghi PrimaDonna S Deluxe Super...
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
Mar 27, 2015 | Coffee Makers & Espresso Machines
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
It is says fill the beans even if the are full, snd dont make a coffee
Your grinder is probably clogged with fine powder. Set the grinder adjustment to a coarser grist, and see if this pushes out packed coffee from the grinder. Open the lid for preground coffee and clean out the outlet from the grinder.
It is the tamper in the brew unit that feels if there`s enough coffee before brewing. If this gets to far down during tamping, it will send a message to the mainboard that there`s not enough coffee, and the message Fill Beans will appear.
Aug 02, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Grinder is not working
http://www.delonghi.com If your machine is still under warrenty they will tell you by numbers on the bottom. If you have receipt, even better. They will send you a new machine for shipping costs only. If machine is out of warrenty they will tell you where to get repaired. Very easy to deal with.
Jun 07, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
Saeco coffee machine
I think your grinder engine has broken and have to be replaced.
Oct 05, 2007 | Saeco Coffee Makers & Espresso Machines
DeLonghi ECAM 23.450 S Espresso Machine & Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
