Question about Freezers
How to hook up water line from sink to icemaker.
Have a kenmore coldspot top freezer with automatic icemaker. need to know how to run the water line from the freezer to under my sink.
  • 358 Answers
You have to put a T between the cold water valve and the faucet, then run a plastic or copper line to the refrigerator(the size could vary from 1/4' to 3/8", you have to look at the water valve in the bottom back of the refrigerator).
Posted on Apr 24, 2009
What size water line do I run for my kenmore all freezer ice maker
If it's a new in-wall run to it, standard 1/2" is fine. From the wall to the freezer you can do 3/8" or 1/2"
An ice maker doesn't use a lot of water so you can consider it a low demand system. If you're connecting from wall to freezer most hardware stores have premade hoses; just like the water hoses for a washer or a toilet.
Jan 24, 2015 | Kenmore 18.6 cu. ft. Built-In All-Freezer...
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
Kenmore refrigerator with a bottom freezer leaks water on floor
Hello Wayne,
You already mentioned the reason for the excess water. When the freezer automatically defrosts itself once every 24 hours the melted water drains down through a tube down to a water pan at the bottom of the refrigerator where it sits and supposedly evaporated by the fan back into the atmosphere. However in your case the excessive dust is preventing the evaporation phase to occur by the fan. You need to vacuum as much of the dust as possible and your problem will disappear.
Good Luck
Rich Lilja
May 22, 2017 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
Kenmore Coldspot side by side. The ice maker will
Hello. You will need to replace the icemaker. The swicth in the head is causing the arm to stay up and is not repairable. If you can get me the model number I can get you the part number.
Jul 15, 2009 | Freezers
I recently moved my Maytag refrigerator model MSD2554F from on part of the kitchen to another. It took me several days before I hooked the icemaker back up. I also replaced the water supply line for the...
Hi, Remove the line to the icemaker from the inlet vavle and blow through it. You can tell if it is blocked or not.
It might have frozen in the inlet tube through the wall of the freezer.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Freezers
Items in freezer melting, Ice maker empty, fridge feeling warm
hi there,
you have 2 problems:
frist check the freezer thermostat and make sure that it's set to at least 5 or 6. if that is okay and you still have this problem, you may need to have the thermostat replaced and maybe more.
as far as the icemaker, if it's just the ice part that does not work, i would recommend checking the valve and water line coming into the icemaker.
can you tell me if this is a side by side or a top or bottom mount freezer? if you have the model #, that would be great.
Oct 10, 2008 | Kenmore Freezers
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
323 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
