Question about Durabrand DU1901 TV
Durabrand 21" tv picture distorted
The tv was just out of guarantee when this problem occured. The tv picture doesnt fit the screen correctly it kind of elongates it making faces look long and squashed together and slightly distorted. Also at the bottom there is a bit about 1.5 inches thats not part of the main picture but a bit extra a second bit of the picture. Now if I press picture size on the control where it used to change to the widescreen view in the middle of the screen with two black strips at the top and bottom it now only has a black strip at the bottom with the widescreen type view pushed up to the top but its still slightly distorted. Any sugestions with this would be appreciated Thankyou
    Genius:
  • 1,694 Answers
To properly diagnose this problem,access to the servicer menu will be important.Also,the service literature for the horizontal and vertical circuits may be needed.Contact a tech who can help you that is familiar with Durabrand.
Posted on Sep 25, 2007
SOURCE:
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Why does the screen have Black Border around the picture , picture distorted?
There are connectors and circuitry that control the vertical and horizontal picture image generation that need to be at the edges of the screen. The border simply covers these connectors and circuitry so the user cannot see it. Newer models of flat panel TV's solve this problem better to get more picture real-estate to the user. Flat panel TV's are not like the original CRT (cathode-ray) TV's of the past that had borders to conceal a non-linear distortion that occurred at the edges.
Jun 23, 2014 | LG 37LC7D 37 in. LCD HDTV
My 21" Plano TV , replace the Picture Tube becous
It sounds to me like it has the wrong scan coils fitted to the replacement tube and there is no fix for that. You will need to fit the correct tube or have the old tube re built.
Dec 28, 2010 | Samsung Televison & Video
Distortion and horizontl lines
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Thanks.
Nov 16, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
The picture doesn`t fit the screen. Daewoo DWX-28W5GB telly
Sometimes the box that sends the signal to the TV preconditions the signal to 4x3 or 16x9, depending on the capability of the TV. I always opt to the "no fit" option and allow the intelligence of the TV to fit the screen.
If you have "off air" TV signal without that preconditioning, I cant help.
Oct 02, 2017 | Daewoo DTQ-20U9SC TV
I cant get my durabrand freeview box to work.
i have pluged in all the plugs to be in and all in the right places but i have no sound but im getting a picture ??????
Nov 22, 2009 | Televison & Video
Distorted picture.
Is the menu text clear on the screen, when it's focused correctly. Or is that also distorted.
If the menu text is OK then the picture signal is dodgy. could be due to a bad earth lead on the video cable.
Is it distorted on all signal inputs
Oct 30, 2009 | Panasonic PT-LB20U Multimedia Projector
Main screen has no picture
go to you`r pics and change wich pic you want.
Jun 27, 2009 | Durabrand DUR7 Portable DVD Player
Is it broken? Please help!
Hi it sound like you a problem called east west correction. But you will need to take it to a repair shop to fix it. My self i charge about £30 to fix this kind of fault. But dont know what others charg All the best Bob
Oct 17, 2007 | Bush 5693D 24" TV
White blurry screen
Your Having a Problem with the High Voltage Transformer in the Set,You can pull the Back off(Not Advised)And you will find two controls on the Flyback*The Flyback is the Unit that has a Red Wire coming out of it Going to the Top of the picture Tube,with the set on adjust the One contol that says Screen,Till the Picture is Normal....Good Luck
Jul 16, 2007 | Durabrand DU1901 TV
Televison & Video Logo
181 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
