Question about Brother Sewing Machines
Malfunction error Y PM - Brother Sewing Machines
I can't clear out a D4 error message on my singer patchwork machine. I have cleaned it out several times and it still won't work.
Try contacting Singer support. Am unable to locate any information regarding this Error Code, so it may be a technical malfunction:
History Singer Sewing
Jan 16, 2017 | Singer Sewing Machines
Embroidery attachment malfunction. turn machine on and off as instructed but still receive malfunction error.
try taking the attachment off and see if that removes the error and if not then their could be something wrong with the computer or a sensor
Jun 18, 2015 | Sewing Machines
Error code y-pm
The embroidery unit has two pulse motors (pm), x and y. Y goes up and down, x goes left and right. So the machine is not seeing the y pulse motor moving. This could be the motor itself, a bad cable, a circuit board or a mechanical bind.
Probably needs to be serviced.
Feb 25, 2015 | Sewing Machines
How to repair error codes on meistergram pro 1500 embroidery machine
Are you asking what an Error Code means and then how to fix the cause?
Error Information...
In case of incorrect operation or machine malfunction, the screen will display the
description of error or icons to inform you.
CL key [CL] Clearing...
This key is used for clearing errors, information or data such as stitch count and frame
coordinates.
Error codes are in the Single Manual (final) pages 68 thru 73
Download this manual's .pdf file...:
http://www.pantograms.com/images/meistergram/Meistergram_Single_Manual_Final.pdf
Feb 08, 2015 | Sewing Machines
How do I fix an x-pm brother 4000d error
Call the Brother toll free service line
Dec 14, 2014 | Brother Sewing Machines
What is code TH-PM ? Brother Innovis 4000D... and how do I fix??
This is a pulse motor failure. You cannot fix this without testing mainboard and Pulse motor. Take it to a mechanic. Sorry for the bad news
Nov 13, 2014 | Brother InnovIs 4000D Computerized Sewing...
Malfunction error tg pm
question is unclear. I had one of these super nice machines and it's one of the most advanced "auto-thread" mechanisms in any machine.
Go to an authorized Brother Repair shop and have it tuned- up and get more advice on how you might be able to DIY???
Feb 01, 2014 | Brother InnovIs 4000D Computerized Sewing...
Malfunction error PF-PM on Brother Innovis 4000D. HELP!!!
try unplugging it and letting it rest for 20 minutes? Sometimes that will reboot it.
Dec 10, 2013 | Brother InnovIs 4000D Computerized Sewing...
Error on Brother Innovis 4000d sewing machine
You probably need to take it in for service. Thread guide pulse motor (TG-PM) is jammed with thread. There is a new shield that that can install to keep this from happening again.
You can gently try to move it with the machine on and see if that works, it is the little shuttle that goes up and down on the front of the machine, it is probably stuck where you can see it.
good luck!
Jan 10, 2009 | Sewing Machines
Sewing Machines Logo
355 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
