Question about Lenovo 59368543 TPC TPC S6000 10.1 inch MTK 8389 1G 16G
Can't move apps to SD card on lenova s6000 - Lenovo 59368543 TPC TPC S6000 10.1 inch MTK 8389 1G 16G
How do i move apps to my sd card
      Move Apps to SD Card Using Application Manager
      1. Navigate to settings on your phone.You can find the settings menu in the app drawer.
      2. Tap Application Manager.
      3. Select an app you want to move to the microSD card.
      4. Tap the Move to SD Card button. If you don't see a Move to SD Card button, the app cannot be moved.
      How to Move Android Apps to an SD Card - Tom's Guide
      www.tomsguide.com/us/move-android-apps-to-sd-card,news-21279.html
    Feedback
    www.tomsguide.com > Android Apps > How-To
Jan 24, 2016 | Tablets & eReaders
How move downloaded apps to sd card
call your cust service for the manufacturer of your device
Dec 26, 2015 | Tablets & eReaders
How do i move apps to sd card
not all apps can be transferred to sd card. some built in apps are not transferable to sd card. If sd card has no light then that apps cannot be transferred to sd card.
Oct 21, 2015 | Zeki Berk Ulu 7" Dual Core Tablet w/...
How to transfer apps from memory to sd card
Ik t depends on the phone you have. In case of an Samsung android device here is what you can do:
- Go to settings
- Swipe to Applications
- Select Application Manager
- Swipe to SD Card
- Tap on an app with a empty tick box next to it
- Tap Move To SD Card
Now wait for a while and you'll see the button change to Move To Device Storage. The app is now, partially, on the SD card. Going back one screen will now show a green ticked box. This will not work for every app and you'll have to redo this each and every time the app is updated. Also be sure not to move apps of which you use a widget on your home screen, the widget will disappear.
Aug 22, 2015 | Cell Phones
Depends a little on the make/model and version of Android, but in general,
  1. Tap on "Settings" either on the home screen, or on the apps page
  2. When the "Settings" page opens, scroll down and tap on "Apps"
  3. Slide the Apps screen that opens to the left, until "ALL" is highlighted.
  4. slide down to the first App you wish to move. Tap on it
  5. in the detail screen for that App which opens, Tap on "Move to SD Card" and it will be relocated to the SD card!
Note that some Apps, and all system apps, cannot be moved to the SD card, and the "Move to SD Card" button for them will be greyed out and unavailable. Note also that a few Apps will not run properly from the SD and will have to be moved back - simply done as when selecting any App that's been moved to the SD, instead of "Move to SD Card", the same button will now say "Move to Tablet"
Dec 31, 2014 | Tablets & eReaders
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Dec 03, 2014 | Tablets & eReaders
Im using a tablet and I cant move apps and games to SD card
Hi if you want move apps to sd card go to settings, application and there press on the app which you want move. On the next screen you will see details about the app and a button move to sd card, just press it and the app gonna be moved to sd card. Bear in mind that some of the application can't be moved you will see then grey button.
Apr 01, 2014 | Tablets & eReaders
Moving apps onto sd card
Hi in order to move apps to sd card you need place the sd card in your tablet go to settings then applications. On the next screen you've got the list of downloaded apps just clik on one of them and then properties screen come up on which in the second row you will see button move to sd card. Just press on it wait few seconds and your apps is moved. Repeat this for every app but bear in mind that some of the apps can't be moved to sd card Regards
Dec 26, 2013 | Samsung Galaxy Tab Tablet PC
Why i cn't install apps on my sd card for galaxy
Try installing App 2 SD from Android Market. You should be able to move the installed apps to SD card using this application. Galaxy Mini comes with Froyo and hence you should be able to use this app and move possible apps to SD Card. Moving the app to SD card also depends on whether the developer has enabled the feature to move his app to SD card. App 2 SD will only be able to move the apps which have this feature enabled by developer to SD card.
Hope this helps.
Jul 16, 2011 | Android Apps
Lenovo 59368543 TPC TPC S6000 10.1 inch MTK 8389 1G 16G Logo
228 people viewed this question
Top Lenovo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Lenovo Audio Player and Recorder Expert? Answer questions, earn points and help others
