Question about Russell Hobbs 9379 Classic 4-Slice Toaster
How do you use the warming rack and have the toast stay warm while still using the toaster?
2 Suggested Answers
SOURCE: russell hobbs toaster 9379 bread carriage handles
bought a new toaster I would like any account you have created for me to be deleted. thank you
Posted on Dec 23, 2009
I need part # 30 sliding rack for a Black & Decker Toaster-R-Oven Countertop Oven/Broiler
Fixya does not sell replacement sliding racks. Check with a local appliance parts supplier.
Jul 05, 2016 | Black & Decker Toaster Ovens
Why won't my calphalon toaster oven toast top of bread? Why?
If both the top and bottom elements are working then you may need to re-position the rack closer to the top element for even toasting. If there is only one rack position available then you may need to flip the bread and toast it twice.
Oct 06, 2014 | Toaster Ovens
I didn't get a manuel and the toast does not go
The Instruction Manual for your West Bend 78224 QuickServe Toaster is available here:
http://www.westbend.com/supportdata/L5670-QuikServeToaster-ALL.pdf
Uneven or ragged edges on your toast can catch on the toast rack and prevent it from siding through on to the serving tray. Trim off any ragged edges.
Thank you for using FixYa!
Sep 15, 2011 | West Bend 78224 Toaster Oven
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
Toast rack won't stay down, and I can't figure out how to get inside to look at it.
Simple, hold it down all the way, for at least 3 to 5 minutes, with nothing in it.  Then release it, and try it again.  It should work.
Jul 28, 2009 | Sunbeam 3802 Toast Logic 2-Slice Toaster
Toaster only toasts on one side
Please ensure that the "Bagel" function is not selected (LED is not lit up). The Bagel function will toast one side of the bread while only warming the other side.
Mar 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Not hot toaster
you have to ask the guy you got it from if they have a spare part for it dont forget to bring it with you
Nov 04, 2007 | Oster 6297 Toaster Oven with Convection...
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Russell Hobbs 9379 Classic 4-Slice Toaster Logo
23 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
